JOIN NOW LOG IN
Mirror too close to the wall for a sconce
Posted by corky1_2008 (My Page) on
Wed, Nov 18, 09 at 1:47
Help! The placement of the rectangular mirror with pivot mounts in my powder room is too close to the abutting wall. I had originally planned sconces on each side of the mirror but that will not work. My designer suggested one sconce on the wall abutting the wall next to the mirror. I am not sure that is the correct answer. I was thinking of putting a bar across the top of the mirror but read that this would cast wierd shadows on your face. My only other choice is too place a light on the same wall as the mirror but that would end up right in the middle of the wall between the sink and the toilet. I think that would also look strange. HELP AGAIN!
RE: Mirror too close to the wall for a sconce
You can also hang two pendants from the ceiling, on either side of the mirror, where the sconces would be, in a perfect world.
Oh, that is a bummer. I just got finished planning out a similar situation and had to make a compromise by using a narrower mirror than I had wanted, and very skinny sconces.
FYI I did find some sconces less than 4" wide.
Can you get a different mirror?
If you consider sconces, as Pirula suggests (which we did consider) just make sure they are located more than 3' horizontally and 8' vertically from a tub edge or shower door. Otherwise it is not technically up to code, and your inspector might flag it.
Why not put the sconces on the mirror? That's what I'm doing. Mirror to the ceiling and to the walls on each side - sconces on the mirror? Will give more light too.
I think the OP has one of those cool pivoting mirrors, a whole different look. We did originally plan to put the lights on the mirrir... but when i found out that the custom mirror with holes cut was >$250 versus the $40 Ikea mirror.... well I decided that a slightly narrower mirror with sconces on the side was just fine!
We had the same problem - had to replace the sconces with a top vanity fixture. The electrician told us that actually this would work better than pendants as far as quality of light goes. Pendants are good for highlighting certain areas (like in a kitchen), but can be unforgiving for activities such as putting on make-up, etc. Our top fixture looks/works fine!
We have the same situation as you. We have a 67 inch vanity that is fairly close to the doorway so we didn't really have space for a sconce on the side of the mirror. We consulted a bathroom lighting designer and he suggested placing the sconces (lugarno from Restoration Hardware), on top of the mirror and then place three cans in the ceiling across the vanity, thus light would come from different directions and help create more flattering light. We opted to not go with the cans, and, are just going with the sconces on the miror. We will also have a light fixture over the tub, and a can over the shower drain. For ambienece lighting we will have lighting in our linen cabinet and lighting underneath the freestanding vanity. Good luck!
I am really happy with the three-light fixtures (AKA vanity strip) I have replaced in the two minor bath remodels we are doing. The light is fine for makeup application and you don't get weird shadows. Picking these out was the most fun for me, using a local lighting store. To me it is like jewelry and a lot less stressful than choosing tile, counter top, vanity, etc. My room is 5 feet x 7 feet and my inspiration bathroom did not have sconces so I never had my heart set on them.
inspiration image
another inspiration (I should have kept this GardenWeb person's name!)
small tile accent trim wide strip
What did you decide to do Corky?
Andreadeg - could you post some picts of your bathroom with the Lugarno sconces on the mirror? I am running into the same issues with my master bath reno, and I'm considering the Lugarno triple sconces.
Thank yoU!
