Mon, Sep 3, 12 at 23:22
| I think it would be easier to tile & than put the sink on top. Then caulk around the sink and tile. The tile would look better IMHO but I've never done this sort of thing before. |
| Enduring, thanks for replying. I do think you're right that it would be easier to make the tile edge look better since it would be under the sink. Hm, I guess I'd better check the sink specs for how thick the countertop can be. thanks again! |
- Posted by bill_vincent (billvincent@hotmail.com) on Tue, Sep 4, 12 at 11:36
| It can go either way, but going under will look much cleaner. As for the specs, it shouldn't matter. The only thing that should matter is the size of the hole cut to accomondate the sink. |
| Bill_V, thanks for replying. It does sound very attractive to tile without having to mess with (or mess up!) the sink. I looked again at the cutout and yeah, it's a nonissue. thanks again! |
| Most definitely tile the top, then insert the sink. I'll be cleaner visually, and cleaner in terms of being "cleaner". Less dirt. |
| mongoct, thanks for replying. It's a clear consensus! Tile first, *then* sink on top of tile (with caulk). thank you all for your help! cheers |
