Sun, Sep 16, 12 at 22:19
| Can you mount something on the side of your tower cabinet that either stays in place or is adjustable for you to pull out and use as needed. The other thought is recessed wall lighting that would be recessed into your mirror somehow. That would be sort of like attractive can lighting. Or could you have track lighting that runs up and down your mirror in channels. You could lower them when you want to put makeup on or rise them to a nice level for general use...No I've got it, you could put a Rev-a-shelve type pull out narrow unit into the side of the cabinet to the left of the mirror. This unit would have the lights mounted and a mirror in the center of the thing. Can you picture what I mean? |
- Posted by joshuasamah (My Page) on Mon, Sep 17, 12 at 0:22
| Sochi, the best mirror I have found for makeup is lit from behind. The ones I have used at various hotels have been large rectangular or square. No shadows, soft lighting, etc. I tried to copy a picture to give you an idea but wasn't able to. I searched under electric mirror. Maybe you could take a look at that type of mirror. HTH |
| Enduring, I think I can picture it. I'm sure my cab maker could manage it. Essentially have a flat panel that can spring out with an electric mirror (ie a mirror with two bars of light on either side). That would be perfect for make up. I could also buy an attractive lighted mirror to sit on the counter. I wouldn't mind having the back mirror lit for when I do my hair etc., as I really don't do much make up. The area will be mostly used for doing hair, putting jewelry on, lipstick, brushing teeth, etc. I think two small tall lamps will give appropriate soft side lighting, but counter space is at a premium and the two lamps might look odd flanking that 24" vanity space. If I move one lamp to the right of the sink the light on my face would be uneven. |
