clear gasket necessary on frameless glass shower door?
nanabella (
Sun, Sep 23, 12 at 13:51
| The frameless glass doors are in on my newly tiled shower. Why oh why is there a gasket 3 feet tall on the door itself? I understand it being at the bottom but I think it looks awful. I can't find any pictures in magazines of a clear gasket on a door. The contractor said it was to keep water from going out. Well, if he maybe measured correctly would we need that? Thanks. |
RE: clear gasket necessary on frameless glass shower door?
| Pretty much all of the time I have seen a hard L or similar on the panel if there is one. If not it would be on the door. Either way there is always a seal unless you want the water to splash out. So I would tend to believe that "Well, if he maybe measured correctly would we need that?", yes it in needed. And perhaps research should be done before making such a broad statement about him measuring incorrectly. |
| We have a fremeless shower door, and it has clear gaskets. It was laser measured, and fits perfectly, but without a gasket, water would be all over the floor outside the door. It's necessary, in my opinion, and I don't even notice it. It's easy to peel off, however, so take yours off, and see if you can live with the leakage..... |
| My husband measured perfectly and we DON'T have a clear gasket on the side. We do have one the bottom only. I'd say our 'gap' is between 1/8" and 3/16" -- so pretty tight. In a typical 15 minute shower in my very small stall (so lots of potential for splashing), we leak about a teaspoon of water onto the bathmat -- so not a big problem. Of course, bigger gap -> bigger problem. |
| Also depends where the shower head is aimed but the company I work for and all the local companies i know of use them. The largest shower door hardware supplier in the country sells them by the truckload as well as every door supplier I know of. |
| Thank you for telling me like it is! I read about the "measurement" thing on another page. Obviously what we see in the magazines is not what we really need on our doors at home. |
| Take it off and see what happens. If there is not water outside, leave it out. |
