| Hi,
my husband and I are still in the process of fixing up our "new" old house (a small 1952 ranch), and our current project is the upstairs bathroom. We can't afford the full-blown remodel we'd like, but we need to do something about the floor. When we moved in, there was nasty carpet on the floor. We discovered it was constantly damp along the edge of the tub and around the base of the pedestal sink. When we ripped out the carpet, there was vinyl sheet flooring underneath, which was soaking wet and moldy. I started to peel it up, beginning in the corner at the tub's edge and around the sink. It was so wet, it came up pretty easily. But once I got that off and down to the wood subfloor (underlayment? I can't keep them straight) I could see that it was completely rotted in the corner next to the tub, around the base of the sink, and around the base of the toilet. There are small holes where I can actually see through to the basement below! It seems there had been a persistent slow leak from the sink that had been left for a long time. It's fixed now. Once all the old flooring was pulled up and it had time to dry, all the squares of wood subfloor became warped and cracked. Actually, some of them are so badly warped that they pulled up the nails (which are all rusty). The floor is so bad in so many places, we'd like to tear it all out down to the floor joists. The joists appear to be in good shape (we have access to them from the basement). Once we expose the floor joists, how do we replace all of this? I have never done floors before, what are the materials we need and in what order do things get laid down? We eventually want tile on the floor, but we can't afford the tile we want right now, so for the moment we plan to put down vinyl. Does this make a difference? Are there different types of subfloor/underlayment for vinyl and ceramic tile? If we put one kind down now for vinyl, will we have to change it when we are ready to tile? And how do we remove the vinyl when it's time to tile? As you can see, I'm a novice and can use all the help you can give! Thanks so much! April PS... i've attached a photo of the bathroom before we ripped up the carpet, just to give you an idea of layout. |
Here is a link that might be useful: Bathroom Carpet
| Putting down a new floor (especially when you have access from below) is not technically hard. It is a lot of work. I'd consult a book or two to make sure I haven't glossed over some of the important points, but off the top of my head, here's the order: |
- Posted by weedyacres (My Page) on Fri, Sep 26, 08 at 22:51
| Nigel's subfloor instructions are good. Here are my answers to your additional questions. I've only laid vinyl once, and torn it out twice, but in all 3 cases on top of the subfloor, which remains through any type of flooring, there was an ~1/8" underlayment of luaun, screwed down every 8" or so. The vinyl is then glued to to the underlayment. Ripping it out entails a wonderbar, hammer, and a little elbow grease. Ok, a lot, as you have to pry out all the screws too. But you could tear out a bathroom your size in an hour or two. Tile requires a different underlayment: cement board or (WAY better) Ditra (google it if you don't know what it is). So you've got to tear out the vinyl with its underlayment (you're not going to separate them anyway), add new underlayment, and tile over that. |
| Putting down a new subfloor and underlayment is a DIY job. As the others suggested, get a home repair manual to get a better idea of the other posts instructions. The manual is a good investment. Enjoy learning and working on this new project...you can do it. Casey |
| Thanks everyone. I've requested some diy flooring books from the library to better gauge whether or not this is something I can tackle. If we decide to get outside help, where would I begin finding someone? And how much should I expect to pay? Thanks again! |
| Flooring books may or may not help... try also the general purpose home books (the Big Orange Box has one called "Home Improvement 1-2-3", for example. It isn't very good for the subfloor part of this task, but has okay information about the plumbing and finish floor side of things.) If you don't already own one like this, I'd suggest you get one for everything else you might want to do around the house. There's no perfect category of trade for this job. Part of the complication is that plumbing usually requires a license, so you'd be taking a bit of a chance to have an unlicensed individual working on the plumbing. If you go to a plumbing company, they might have carpenters that they use, but it'll cost a little more for the coordination they have to do. If you approach a general contractor, they'll have the carpenter and connections to plumbers, but they might also view this as a small job and upcharge you for the bother. A handyman without a license to do plumbing would probably do an okay job, but there's a possibility that they'd botch it. If it was me, I'd try and find a combination licensed plumber/ handyman. You'll pay a little more for the plumbing ticket, but it may help you sleep better at night. My gut tells me that this would come in under $2000, but there are too many unknowns to even call that a guess. (And double that if you live somewhere really expensive, like California or NYC.) Get a couple of people out for a quote. Ask for proof of liability insurance and call their insurance company to see that they're currently covered. To drag you back to the DIY side of things, if you feel competent and safe with a circular saw and a drill, and own basic plumbing stuff, then I think you can do this. Double that vote of confidence if you have another bathroom in the house to use while this one's being wrecked. |
| Thanks justnigel. I've requested the "Home Improvement 1-2-3", as well as a couple of other general home improvement books ("How Your House Works" visual guide seemed like a good choice). We live in Utah, but $2000.00 still seems like an awful lot of money so we'll probably give DIY a try! And we do have another bathroom we can use while this is in progress (thank goodness!) I'm not really sure though where the plumbing specialists come into this? I understand we will need to temporarily remove the toilet and sink, but other than turning off the water and plugging the flange, is there something I'm missing? We hadn't planned on moving or changing the fixtures. |
| I didn't mean to scare you about the license stuff... it's just one of the many things to be aware of when getting trades into your home. In general, if you have an unlicensed individual do work that should have been done by a licensed person, then their screw-ups become your problem. In your case, the plumbing specialist mainly comes into play if something goes wrong. Removing and replacing fixtures isn't hard. One more bit of advice, if I may: check beforehand if your toilet and sink have shutoff valves. If they don't, then your first task is to put shutoffs there, so you can get water to the rest of the house while you're working on this room. The compression fit ones work quite well. And I might be completely wrong about the $2000. Not a bad idea to get at least one quote. (On the other hand, I'm sure the DIY will be very satisfying.) |
