Remove or perforate original vapour barrier?
alan_s_thefirst (
Thu, Aug 9, 12 at 14:55
| Ok, one more question: If I'm going for an applied waterproofing agent - Kerdi, or a paint-on over backerboard, do I remove or perforate the original vapour barrier? One section of the shower - only around 2-3' x 1' - is on an outside wall. Should I do this, or should it remain as part of the building envelope? It would effectively sandwich the backerboard between waterproof membranes. |
RE: Remove or perforate original vapour barrier?
| If your vapor barrier is on the outside of the house (outside of the studs), Leave it. |
| It's on the inside, warm side of the studs, as per usual. |
| Leave the original vapor barrier intact and use a waterproof but not vapor proof barrier like Hydroban. |
| It doesn't look like I can get Hydroban where I am and I don't have time to buy and ship...I was planning to use Redgard, but it looks like it's 100% waterproof, so I'd be back to the question of two barriers, so I guess the original one goes. Not sure what to do for a transition, but it's a small area above the shower, about 1' high, 2' long. |
| Mongoct! Question that feeds off this question. If one chooses to use hydroban (and it is not a vapor barrier) does one need to use a vapor barrier also (such as plastic sheeting behind the cement board)? |
