Cast Iron or Vitreous China Sink? Which Would You Choose?
Rareindigo (
Tue, Jul 24, 12 at 23:05
| Narrowed my sink decision down to three - all are Kohler. The Bryant is Vitreous china. The Ellington and Farmington are both cast iron. Which would you recommend - the china or cast iron? Thanks. |
RE: Cast Iron or Vitreous China Sink? Which Would You Choose?
| I love cast iron sinks - especially for a kitchen. They just seem to hold a shine and get less grungy. Good ones (i.e. Kohler) are fairly indestructable. But in a bathroom that's not getting a ton of wear and tear, I think china is also fine. |
| i have 2 cast iron sinks in the bathroom which i really like- very easy to clean, etc... don't have any vitreous china sinks, so can't comment... |
| In a bathroom I think either is fine. It's not like you'll be dropping heavy objects into it all the time, the way you would in a kitchen. I'd go for the one you like best. |
| Pick the one you like the best aesthetically - a vitreous china sink and a cast iron sink will both hold up equally well over time. |
| I had one in the kitchen (Kohler) which held up well but I had to clean with Barkeeper's Friend or pumice occasionally. We rented out our house for about 2 years and when we moved back, the tenant had chipped or cracked something in the bathroom sink, causing the cast iron sink to rust and the porcelain to flake off. So just treat it with respect. It worked for about 16 years before the chip. Our tubs are both Kohler cast iron and still holding up (20 years) but we plan to renovate MB. |
| > causing the cast iron sink to rust and the porcelain to flake off. This does happen eventually. The current sinks in my bathrooms are from 1979 and they're just starting to develop rust spots (we have horrible over treated well water). |
| I have cast iron sink in main bath from 1983 and it is rusting at the connection with the drain hardware - we have softest water possible. It's in fine shape otherwise, but to replace it requires a full bath update...tile counter that will be ruined taking out the sink...matching tile bath surround that will have to be replaced to match the updated vanity area, etc. I wouldn't buy cast iron again. |
