JOIN NOW LOG IN
Tankless toilets wall-mounted toilets
Posted by scottage (My Page) on
Tue, Jul 31, 07 at 19:39
I am looking for a tankless toilet which does not require wall tank carrier (one that made by Gerberit). Duravit and Catalano are the makers of tankless/wall mounted toilets available in the US, but require the career. We also have toilets that can accomodate the water source located on the floor. Neorest and Hatbox are in this type. Do you know any tankless toilets other than Neorest/Hatbox which can simpley replace the existing standard toilet w/o major plumbing efforts?
RE: Tankless toilets wall-mounted toilets
In all my research of toilets, I found no other such toilets. I purchased a neorest and a hatbox. I have heard nothing about the hatbox and have actually never used one. I purchased it mainly for aesthetics and size. I have friends with the neorest and they have had no problems.
I am a little concerned about the kohler hatbox from my past negative experience with kohler's silent flush models, but I do understand I should not compare "apples to oranges"
Since I am/was doing a major remodel with new walls, I thought of installing a tankless toilet. However, I decided that they would be too complicated for the typical plumber to repair and I also kept running into obstacles when I attempted to order the carriers. Also, I plan to rent out this house in the future and figured the carrier in the wall might cause problems that a tenant might not notice until it was too late.
Kelley
Cheviot makes a nice wall hung. The tank is hidden in the wall cavity and the effect is very nice. These were installed with Toto S-300 Washlets. I also saw a Caroma wall hung on a rec centre that I was working on. The Glenwall is probably the ugliest wall hung toilet I have ever seen. I guess the big issue with the hidden tank is servicability.
