New Tile Over Old?
Posted by emmi331 (My Page) on
Wed, Jul 18, 12 at 17:50
Home Depot is remodeling my bathroom. I thought it would be a complete gut, but I was advised by their contractor that it's actually better not to remove old wall or floor tile, but to tile over it. This makes the wall, in particular, more solid and secure. Evidently an abrasive will be used on my subway tiles before adhesive is applied for the new tiles. Does this seem right - is it common to apply new tile over the old? Many thanks....
RE: New Tile Over Old?
emmi331, we retiled our large walk-in shower as a DIY project ten years ago, and we tiled over the existing tile, pretty much for the same reasons that Home Depot gave you. It worked out well for us.
FWIW, we took special care to ensure that there would be no path for moisture to get between the existing tile and the new tile that would provide an environment for a mold garden. That meant using epoxy grout, which had the added benefit of providing an environment that is more resistant than cementious grout is to the growth of mold on the surfaces that are exposed after the tiling was complete. You may have difficulty to convince the Home Depot installers to use epoxy grout, which requires a level of discipline to apply that many tile installers lack entiirely.
What home depot contractors describe is not the proper way to tile. It's cutting corners. You will have problems down the road.
is it the ideal installation? absolutely not. But it can be done.
What I tell my customers all the time is this: The new tile and proper mortar will stick to what you put it on. That does not mean that what you put it on (old tile) will not eventually come off the wall. You have no way of knowing how solid the previous installation was and in what condition the studs are in.
That seems strange to me. When I've wanted to do it to save time, money or hassle the contractors all have warned me off. The only time I've done it, and that was just recently, was around an older tub. We took the tile off the wall and redid that. But the tile on the tub deck was 20 yrs old and in super shape so we put glue down and river rock over the top of it. Then we glued and screwed plywood to the tub face and put bamboo over it for a new face. Hopefully we won't come to regret it.
I've done a lot of tile and in the past have always removed the old prior to tiling the new. Particlarly on walls.
That being said, I am currently doing two small bathrooms each about 6'X'6 on the tiled floor. Both currently have tile on a concrete slab. The old tile is solid as a rock and I am going straight over it with the new tile. It will be my first time doing that but there should be no issues since I have a wonderful base for my new tile.
I would be hesitant to let them tile over my wall tile and I would consider letting them go over the floor if your current tile is solid, without cracks and shows no evidence of movement.
Tile over tile is okay in some circiumstances. The ONLY time I'll advocate it over wall tile is if the wall tile being covered is well set in an old fashioned mud job, with no cracks. Then they're right. You couldn't ask for a stronger wall. Other than that, tear it down and start from scratch. For floors, so long as the floor tile is in good shape (no cracks, no hollow spots), and just needs updating, then it's fine to go over it, SO LONG as it doesn't create height issues with doors, or anything else.
I agree with Bill. I completely remodelled my master bath without knowing until I started demo work that it was a mud job. This type of wall work is great, long lasting, though only found on old houses. So I just tore down the shower tiles/walls up to about 4 1/2 feet height as it covered around the bathroom and left the rest of the walls untouched. At that time I didn't know you could tile over tile if behind it was a mud job. I made sure that the wall was straight to the ceiling after applying durarock drywall. Of course I installed the plastic water seal sheet under that first. Then 24inch tiles over the durarock up to the celing. Really really tough job and lots of demo, but if I were to do it again, I would have done tile over tile with a smaller less heavy tile or thin tile. My 2nd bathroom I will do tile over tile with a thin mosaic tile in the shower and the rest of the bathroom I will probably do wainscoting.
