Epoxy grout with calacatta marble tile?
Posted by firsthome (My Page) on
Thu, Jul 5, 12 at 16:04
So we are in the planning/purchasing phase of our master bathroom remodel. When we purchsed the 12x12 calacatta marble tiles for the floor the tile shop owner sold us white epoxy grout. Now after reading the Spectralock website I see it's safe for marble but that white marble may soak up the grout through the sides of the tile and create a 'picture-frame' effect.
Also based on the Spectralock site, Epoxy contains sand and could scratch our polished marble tile.
We purchased the tile and epoxy while out of state so we can't take back/exchange for something else, so I am hoping we can use it. Otherwise we will just have to buy regular non-sanded grout and chalk it up to a learning experience.
Spectralock suggests conducting a test area prior to grouting to see if the results are acceptable. If we do a test area, how long would we have to wait to see results? I am assuming it would need to completely dry to truly know if we have the 'picture frame' effect. It is my understanding that once you mix epoxy you have a 80 minutes to work with it. Is it possible to only mix a little bit in order to test the product or do you have to mix it all at the same time? If we have to mix it all at once I am not sure how we can conduct a true test of the product and results.
- Has anyone used epoxy grout with calacatta marble?
- Could I use epoxy if I pre-seal the tile before grouting (after installation onto the floor) or would sealing the side of the tile prevent a good bond?
Thanks. I appreciate any advice.
RE: Epoxy grout with calacatta marble tile?
Okay-- a couple of things. First, the sand in Spectralock is extremely fine. It's not going to scratch anything. Secondly, I've used standard sanded cement based grouts on polished marble before in commercial installations, and never scratched it, even grouting using a buffing machine and burlap. Secondly, if you're going to use epoxy on polished stone, you ought to consider as part of the process using an epoxy glaze remover. You WILL leave a little of the epoxy matrix on the face of the stone, and it'll be blatantly obvious, because of the polish, If you're having this done by a pro, he'll most likely want a premium for that (and rightly so). As for sealing prior to grouting, it won't help with epoxy.
Thanks bill. So you don't think I will have an issue with the "picture frame" effect? Shouldn't I still test the tile?
Also regarding removing the cured epoxy film or haze -Laticrete suggests using a combination of a neutral pH detergent/water solution and extra LATICRETE SpectraLOCK PRO Grout Part C powder. They also recommend trying a combination of LATICRETE SpectraLOCK PRO Grout Part C powder with Miracle Company � Epoxy Grout Film Remover or Dominion Restoration - Petra 7. Is there an epoxy glaze remover you suggest?
Lastly, will we be ok to go with a 1/16" grout line with epoxy grout?
Epoxy grout with marble is pretty useless and expensive overkill. It's like putting a brand new set of suspenders onto a pair of pants that are so threadbare they're getting ready to fall apart. It's wasted money and effort. The marble is porous, and will need repeated sealing as regular maintenance. You might as well use standard grout and just plan on sealing the entire surface at one time, grout an all. (And none of that sealing will ever prevent the marble from being etched.) All the epoxy grout will do is make the install hell and cost a lot more, and possibly damage the tile itself with residue or grout remover if you don't have a VERY skilled installer who uses the right products and really knows what he is doing.
The standard epoxy removal tool of vinegar won't work in this situation as it will etch the marble, and frankly, I don't know of a product that will remove the haze and still leave the marble undamaged. However, my experience with epoxy is with "bulletproof" porcelain in order to create an almost "zero maintenance" environment, which is the very opposite spirit of any marble shower. I'm sure somewhere someone has created a grout haze remover that isn't acid based, but I'll bet from just my basic knowledge of chemistry it mostly involves elbow grease rather than chemical action.
You may for a while, until the epoxy resins completely cure and dry out. No way around that with natural stone. That still doesn't stop those who wish to do this kind of installation.
Hands down, Petra 7 is tops for removing epoxy haze, but I've yet to see any place where it's available to the general public. Stoine Tech makes an epoxy glaze remover that's almost as good, and IS available to the public, and will not harm polished stone.
I won't say epoxy in general, but Spectralock will be fine.
Now....
Useless, no. Overkill, I'll agree with. But that hasn't stopped those who've really wanted to use it.
I just gave two, one of which is available to the public, and usually pretty easy to find.
My son and I, 2 months ago, cleaned about 2000 feet with the Stone Tech product in about 4 hours on this following installation:
I've installed lots of epoxy grout, and regular grout too. They both need cleaning from time to time. Epoxy can come back to the original light beige color. I use a steamer (cheap steam nozzle device) and a drop of bleach. The other kind of grout can be pretty good too, if you use GroutBoost. Web search this word.
How is GroutBoost & what is it used for?
Our tile dealer is pushing it as a 95% of the way grout stain resistor ADDITIVE vs. the added expense of an epoxy like Spectralock.
Still a rather large $750 upcharge for GroutBoost
Here is a link that might be useful: Groutboost Specs
$750 upcharge for grout boost? How much are you buying? In our area it goes for $65 for a 70oz jug (for 25lb sanded grout). I used Tec Power Grout in my own home and have been happy with it so far.
Our installer used boost in one of the bathrooms, as a way to best avoid stain and mildew. I think it was about $50/bottle. One bottle gets mixed with one container of grout instead of using water. Installer had no issue with using it. I think it was unsanded grout as well (I forget the brand, Tec I think) as we used a combination of glass and subway tile).
We used epoxy grout on the shower floors (ceramic tile) in our steam shower. Grout with boost was used on the walls, because we have some marble mosaic accents.
Not sure yet how much is being requested by our sub but 3 full bathrooms all tiled is what I am guessing right now is what GroutBoost is being used for.
