| How do I use Hydroban on my hardibacker for my tub (with tile flange) installation? I have seen Mongoct's illustration on using Kerdi, in his post that I have linked to below. But I was planning on using the paint on waterproofing membrane for my walls surrounding my alcove tub.
I've read somewhere (?) that after setting the tub to the studs:
So, any corrections to this plan? OR should I use Kerdi to cover my wainscot area around my tub before tiling? If Kerdi is recommended I think the post that I've linked to is very instructive. Thanks for your time in reading this post:) |
Here is a link that might be useful: Kerdi Shower Part Deux
| I will ask my DH and get back to you! :-) He installed the Hardibacker and then applied Hydroban in/on one shower surround and two tub surrounds, so would be better able than I at answering your questions. |
| Thanks cat_mom! |
- Posted by bill_vincent (billvincent@hotmail.com) on Sun, Jun 17, 12 at 21:15
| The hydroban is fine. Just grap a small paint roller, and git rollin!! |
- Posted by bill_vincent (billvincent@hotmail.com) on Sun, Jun 17, 12 at 21:18
| One thing-- although it's not required, I like to use the 6" fiberglass cloth over all the inside corners and seams between the sheets of cement board. |
| Thanks Bill! |
| DH has been inmtgs all week so hasn't had a chance to look at this thread. From what I can tell, DH followed the steps you listed. Just wasn't sure about step #2. I am sure Bill wouldn't steer you wrong! I don't know if DH used fiberglass cloth or ? at the inside corners and seams. I do know he used thinset instead of joint compound for the seams. |
| Cat_mom, thanks for remembering, sometimes my memory is about 2 seconds long:) |
| Mine, too! I will try to ask DH later if there's anything you missed (or that Bill might not have pointed out explicitly). Bill was very helpful in answering DH's questions when he did our bathrooms, so I doubt much if anything hasn't already been addressed. If I don't get to ask him tonight, I promise to do so before the week is out! |
| Cat thanks :) |
| DH reminded me that he furred-out the studs, and then installed the Hardibacker over the tile flange (as described in this thread): http://ths.gardenweb.com/forums/load/bath/msg1120511823883.html As mentioned on the thread I linked, this was suggested by our tile guy as his preferred Hardibacker installation technique (which I think Bill okay-ed on that thread). HTH! |
- Posted by bill_vincent (billvincent@hotmail.com) on Tue, Jun 19, 12 at 23:36
| I don't know if DH used fiberglass cloth or ? at the inside corners and seams. I do know he used thinset instead of joint compound for the seams. If you use the FG cloth and embed it in Hydroban, there's no need for thinset OR joint compound. As mentioned on the thread I linked, this was suggested by our tile guy as his preferred Hardibacker installation technique (which I think Bill okay-ed on that thread). YUUUUP! :-) |
| Then he used the thinset, but not the FG cloth. You would be proud of DH's work, Bill. :-) I know I am! Thanks again for you help and advice!!! |
- Posted by bill_vincent (billvincent@hotmail.com) on Wed, Jun 20, 12 at 19:03
| I wouldn't bother at all with caulk BEHIND the tile. The biggest thing is to fill that big gap at the bottom of the cement board, so you don't have a hollow spot behind the tile, making it easy to snap off the bottom of the tile. That can be accomplished with a stiff thinset. You can then waterproof over the top of the thinset when you waterproof the hardiboard. Save the caulking for between the tile and the tub. |
| Thanks Bill, makes sense to me. |
