Sun, Jun 3, 12 at 14:52
| I have had a Soir�e in my MB for two years now and the bottom of the bowl has stained badly even though it is cleaned regularly. Today I turned off the water and poured CLR in there and let it soak for awhile. I then scrubbed it with the toilet brush..some came off. I then tried getting the rest with a smaller brush but it is impossible to angle a brush to get to the front inside and you can still see the stains. I had resorted to using colored tablets to hide the staining but I don't like to use them. Thanks for any suggestions for techniques or products that might help. |
| You might have to put on rubber gloves and get right in there. I hope you can get it clean without damaging the glaze. |
| That's the toilet I wanted too. Did you get the SaniGloss finish? I wonder if that helps prevent staining. I would call Toto and see what they recommend to clean it. |
