| I am building a new home and the guest bathroom has ended up as an 8' x 8' area. I am thinking of putting a walk-in shower rather than a tub/shower. Do any of you have ideas or suggestions of the arraignment for the shower, sink w/cabinet and toliet? Also, the door can be oriented (if you imagine the 8x8 square) on the east or south end of the square. Sorry I don't have a graph to show the layout I'm not very savvy with the programs that you use to draw. |
- Posted by lukkiirish (My Page) on Sun, Jun 14, 09 at 13:38
| Can you draw your preliminary thoughts on paper first and post that? It's helpful to have a visual even when describing suggestions. |
- Posted by pepperidge_farm (My Page) on Sun, Jun 14, 09 at 16:46
| Is the plumbing/toilet going to be in a particular place? Where are the exterior walls, wet walls... that will make a big difference in how you will approach the design. |
| My scanner/printer is not working..sorry... pepperidge farm...i'm in the planning stages of the house so I guess to answer your question about where the exterior walls are ..if you can imagine an 8'x8' square the exterior walls would be on the south and east sides of the square..this is where the halls are. So therefore the door to the bathroom could be on the south end or the east side. I'm guess the wet walls would be on the north wall or west wall. |
- Posted by spacechallenged (My Page) on Mon, Jun 15, 09 at 8:19
- Posted by weedyacres (My Page) on Mon, Jun 15, 09 at 11:36
| I've got a friend who remodeled an 8x8 bathroom and had a good layout. It had a door in the middle of the south wall, and when you walked in, a double sink was on the right, with the toilet at the north end. The tub/shower was on the left, with a linen cabinet at the north end, across from the toilet. There was a window in the center of the north wall. |
- Posted by spacechallenged (My Page) on Mon, Jun 15, 09 at 13:06
Was it something like this Weedyacres? Sorry on the preview it appears large, but I'm just learning how to do this. ![]() |
| How about a corner shower? |
- Posted by spacechallenged (My Page) on Mon, Jun 15, 09 at 20:13
| thanks spacechallenged, weedyacres, swampwiz for your ideas! spacechallenged...thanks so much for your drawings. I think I'm leaning towards your first drawing but one question where would you put the door for the shower? Or is it a walk in with no doors? I have concerns about the door placement in the 2nd and 3rd drawing, looks as though the door may "run in" to the cabinet. I'm thinking no tub either. My DD thought I should make it an old fashioned type bathroom (our home is a farmhouse style) with a pedestal sink, armoire for a linen closet, not sure if it will all fit though. Any advice, suggestions, photos? |
- Posted by spacechallenged (My Page) on Tue, Jun 16, 09 at 8:22
| What is right outside the bathroom? Is it a bathroom that will be used by the public? The whole family? Mostly one person? - In general, having the toilet right in front of the door would be considered less attractive. In the first layout, reversing the door swing would shield the toilet (and its occupant) from view by accidental door-openers. Of course, you'd need to cut the corner on the shower to make sure there's enough room for someone to step into the room easily and close the door. |
- Posted by spacechallenged (My Page) on Wed, Jun 17, 09 at 11:02
| Sweeby, In the first layout, the entry door is 32" wide. The toilet sits back 3' away from the door. A person standing on the outside opening the door couldn't see the toilet until they stepped in, but I guess if there were a large room outside, perhaps someone farther away might. The point of the corner of the shower wall measures over 1'(the computer program measures 1'9") away from the middle of the door swing that is the closest to it. You can test to see how much room you need and where you normally would stand to close the door. Our bathroom is a little larger and almost identical except our door is on the south wall in that right corner. It opens up where you see the toilet 1st and I agree it's better to see the sink when you open the door. The sink and toilet have about the same area of space. Ours was done in consideration of a future addition and that door will be changed to the way it is in the 1st drawing at that time. Our bathroom is about 9x9 but our door is 36" and there isn't a problem. Our bathroom was designed to be wheelchair accessible. |
| sweeby....along the south wall and east wall are hall ways. So...the doorway could be located on the south or east wall. This will be a guest bathroom. I originally thought of putting the door on the east wall then as you you enter the door the sink would be immediately to the right then a half wall with the shower next to the sink on the west wall and the toliet on the southeast corner. I wish I could draw so that you could see, but maybe you can visualize..what do you think? |
| You could also do a layout like we just did for our master bath remodel, and fit in both a walk-in shower and a full tub. Ours is more like 9'x10', but the same layout would still work spaciously in 8'x8' using a standard 5' tub and a single sink vanity. The toilet is not visible in the picture but just inside the door to the left. A knee wall at one end of the tub forms a side for the shower. The shower was supposed to be enclosed with glass at the knee wall and toilet (but with an open door), however it worked fine without the glass. It's a bit like spacechallenged's 2nd drawing except with the toilet and tub swapped. The room feels spacious because the no solid internal walls divide up the shower/tub volume from the room. The architect spec'ed a pocket door so it doesn't open into the room, though for a guest bath a normal hinged door would probably be better. |
Here is a link that might be useful: Bath pic
- Posted by spacechallenged (My Page) on Thu, Jun 18, 09 at 9:13
| wwu, I really like your bathroom layout. Course, it's all just a matter of preference, but these open bathrooms not only appear nice and spacious, but you can put so much more in the same square footage. Actual photos help so much more to get a realistic perspective. |
- Posted by spacechallenged (My Page) on Thu, Jun 18, 09 at 9:33
| spacechallenged...on the other side of the north wall is the guest bedroom. The other side of the west wall is the kitchen. |
- Posted by spacechallenged (My Page) on Thu, Jun 18, 09 at 23:29
