Mirror Size Question
rachnyc (
Thu, May 17, 12 at 17:06
Thoughts on mirror size...
vanity is 66", planning 2 mirrors and 3 sconces (one in between mirrors and one on either side). which size mirror works better...18.6x30.6 or 21.5x36.6?
thanks! |
RE: Mirror Size Question
| We are working on the same issue! Ours is a 72 inch vanity and only two sconces. On this wall after taping it out we think with sconces anywhere between 17-19, so your 18.6. If you have an 8' ceiling 36.6 would be nice. |
| thanks! i should tape it out instead of just holding up a tape measurer! my contractor said 20x36 is the max i can go, but this motiv mirror is the one i think i like the most. i just wish there was a size in between the 2 it comes in! good luck to you! |
| We faced a similar issue with a 63" vanity. Did not like how individual mirrors would look. So, went with a single mirror with beveled edges installed as if "floating" on the wall. You could still have one made to fit your center sconce. |
| Don't know if this will help, but this will give you an idea of what two mirrors look like over a 62" vanity top with two pot lights and a sconce in between the two mirrors. The mirrors are 24" x 33" (believe it or not, they're the Fenella mirrors stocked by Lowes; the only thing I could find to match the finish on the vanity base).
fnmroberts- Would you be so kind to post a picture of your floating mirror? Thank you. |
thx, kevinmp! beautiful bathroom. the mirrors are great! definitely helps me in visualizing my bathroom. and thx, fnmroberts...v interesting idea to think about! |
| neighborgirl Our update isn't going to be finished until fall when a new vanity is installed but here is a cell-phone photo of the "floating" mirror. It is adhered to the wall without touching on the side or bottom. A ledger board supported it for several days while the adhesive cured, then the holes were filled.
