| I posted this under FAQ for dummies but its kinda specific so posting again... apolgies for the length.
Hi Mongo or any of you other kind souls...,
http://www.faucetdirect.com/delacora-dellsvlv1407-1-2-inch-rough-in/p9 68459 I am trying to pair it with an alsons handheld shower that I purchased...
So I am looking at throwing a third manufacturer in the mix. Jado seems to offer the bling bling trim kit that most closely resembles the style of my Delacora faucet... But, all the Jado 4 port diverters say "Alternates water flow between 3 discrete shower outlets" ( which I read as A, B or C. but no combination thereof... since I read discrete to mean apart or separate...
But then the following Danze says "services up to 3 shower systems" which I would read the same as above.
So I am confused about whether that means that the Jado really would be A or B or AB functional. And assume that I should just go with the non matching Danze - EXCEPT to further confuse me, Faucet Direct recommended a Hangrohe which I ordered and then had to cancel because Hansgrohe told FD I can't mix this four port diverter valve with the Delacora... but I have no idea why.
They all appear to have 1/2" valves, so if I use the 3/4" tubing and supply valves I really struggle to understand why I couldn't mix and match the rough in valve with another brand of diverter valve... Finally, this Brizo 6-Setting, 3-Port Diverter Rough In Valve really doesn't match, but reads Diverter Features:
So I guess at the end of the day can I simply go with the Jado or any of the above except the hansgrohe; or can someone help me ferret out the differences? Many thanks in advance!
