xpost: AO catarina grout size
Posted by cottonpenny (My Page) on
Tue, May 15, 12 at 12:01
What size grout joint did you all use on AO catarina tile (or similar)?..
Flooring store says I can have 1/8" for an extra $265 for the master bath, otherwise they will do 3/16".
Is 1/16" less grout worth it?
RE: xpost: AO catarina grout size
Our tile guy doesn't charge extra for different grout widths (unless that was factored-in?). We chose 1/32" grout lines for the travertine tile in our FR/guest bedroom/entryway. Our tile guy laid out a few tiles showing 1/16" and 1/32" lines, and we (he, DH, and I) decided to go for it with the 1/32". We knew our tile guy has the skills to lay tile with that tight a grout line.
So, in our case, we preferred the look of the tighter grout lines (the difference in widths was noticeable). Only you would know if the price difference is worth it to you.
I have a grout phobia... so it would matter to me.
You could ask them to reconsider their fee. Sometimes all you have to do is ask.
I looked at the Caterina. I ended up with something similar, but polished.
Here is a link that might be useful: My tile.
Victoria - what grout size did you end up using?
Any photos?
A tigher grout joint requires better tolerances on both tile and flat floor.
The upcharge which is small--- may be for his time to spend to level more to get a flush tighter grout joint.
We used 1/16". I would have liked to go smaller, but my husband (who is also my tile guy,) was concerned that he could not meet my expectations for a "perfect" installation, with such a thin margin to work with.
I do understand what the fee is for. But it's been my experience that sometimes these things are negotiable.
Link to photos: My Tile
You're right. They are. Many times an installer won't come close to charging what it's worth for the extra time it takes him to work with a tile that isn't meant to have that tight a joint until someone starts telling him it's too much. At that point, he will.
Victoria - lovely! your dh did a great job! wish we were so talented!
Bill - AO specifies a 1/8" grout line with this tile for flooring applications, so they are charging me extra to go with the manufacturer recommended grout line instead of bigger. So I didn't think it was unreasonable?
Here is a link that might be useful: Catarina tile
My bad-- I forgot Catarina is rectified. You could actually go smaller than that.
