| Hi, all,
I need some help on caulking around the shower pan. I have a cut pebble shower pan that's installed about a month ago. It has been working fine but some white stuffs showing up around the pan. It seems like the clear caulking is turning white in some sections. My contractor came to replace the caulking, but a week later, the same area still turns white.
Thanks a lot for your help!
| You're not caulking the floor of a shower to prevent water entry (if the shower was constructed properly). Water that gets behind the tiles, pebbles, in the grout, etc.....Should be able to slowly drain out. The caulk should be in the corners/edges. Just to match the grout, yet, be more flexible than grout. If it's turning white due to moisture behind it, it may be coming from the porosity of the tiles and grout above? |
