Question about 6 setting diverter
Posted by bowyer123 (My Page) on
Thu, Feb 14, 13 at 22:48
Our shower has a rain can, 2 body sprays and a traditional shower head. The diverter is a (Brizo) 6 setting unit.
My question is this: What combinatiobns will operate with this diverter? All 3 pieces or just 2 at the same time...I'm think 2? Not sure how it will work, but am curious. If all 3 work at the same time, how will the water pressure be?
Thanks for your help!
This post was edited by bowyer123 on Fri, Feb 15, 13 at 7:59
RE: Question about 6 setting diverter
Ours is a similar setup--a traditional shower head, overhead raincan and a handshower (instead of the bodysprays). Odds are the body sprays are on the same line (can't operate 1 at a time). Depending on how the plumber set it up, you may be able to run all 3 at once. Water pressure does decrease slightly with each additional water output line that is opened.
Hope this helps!
That does help, thank you!
I hope all three areas can be used at once. I will see the plumber next week and will hopefully get to see it in action....then I will know for sure.
