JOIN NOW LOG IN
Do I have all shower components needed?
Posted by bikrchc (My Page) on
Sat, Feb 6, 10 at 21:26
I have just finished scanning all of the posts in this section, and hope I have only one more question.
My current bathroom has original 1926 fixtures - fixed shower arm, separate hot and cold porcelain handles, diverter located between the hot and cold handles, and a tub spout.
My co-op now requires a thermostatic valve.
All I need is a tub spout and handheld (no fixed shower arm). If I buy a wall union, hose, handheld, slider bar, handheld holder, tub spout with diverter, thermo valve rough-in, and trim with temperature and volume control handles (both in same trim), do I need anything else?
Thank you. This is so overwhelming.
RE: Do I have all shower components needed?
Looks like you have pretty much everything. Some tub spout diverters can be finicky when used with valves from another manufacturer, if it's a package deal with the valve all should be fine.
Since you're in a co-op, you'll probably need the thermo valve to have "stops", you can check your restrictions to see if it's required. Most valves are sold "with stops" or "without stops".
Even if it's not required, stops are a good thing to have in a multi-unit building, you can do maintenance on your valve without having to shut down the building's water supply.
Clarification re: Do I have all shower components needed?
Thank you, Mongoct, for the information. My current picks, including the tub spout, are made by Grohe but I don't know if the valve has stops and the building super didn't mention it. I will check this out.
Is valve maintenance a normal occurrence? I am operating, perhaps incorrectly, under the impression that my plumbing fixtures shouldn't require maintenance for at least 10 years. (If so, I'd better buy more tile now! :>)
A good valve will give you 15, 20, 30 years of maintenance-free service. The building I'm in in Manhattan requires stops. Most in NYC do, but I'm sure there are other locales where it's not a factor.
I live in the Bronx and have heard that the plumbing requirements that are being instituted in Manhattan are making their way uptown. It turns out that my thermo valve has stops so I'm all set there.
I am writing as I was told something today about shower fixtures that had been suggested to me previously. It was suggested today that instead of purchasing a trim that has a temperature and volume control, and a tub spout with a diverter, I instead buy a regular tub spout, and buy two volume controls and one temperature control. By doing it this way, I can place the controls anywhere I want, say, the temperature control half way between the handheld and the tub spout, one volume control near the handheld and one near the tub spout. It is also less expensive to buy three separate trims and valves, and I don't have to deal with the diverter on the tub spout. I can also have water coming out of the handheld, tub spout, or both.
Neat-o!
