| If you want the see-out-but-not-see-in effect, for daytime use look at mirrored window films. If you go that route and that will be the only treatment used, mirrored films give privacy to the side of the film that is darker. Typically in the day time people won't be able to see in, but at night when your bathroom is lit up and it's dark outside, the effect is reversed...you won't be able to see out but people outside can see in. So while that type of film is good for daytime, you'll need to couple it with a curtain or blind for night time. Or you can go the route of a frosted film. You'll retain some light transmission, but lose the view. There are numerous styles of frosted films, and the amount of light they allow to transmiss does vary. There are stained glass films too if you want to go decorative. That aside, for window shades, I like top-down-bottom-up for any actual window shade. If you're not familiar, with those shades you can lower it from the top (usually most effective in a bathroom), or raise it from the bottom, or both. If you can lose a little of the view and natural light during the day, then go with just a T-D-B-U shade. If you want to preserve the entire view, your best bet will be to use a reflective film. That'll give you privacy in the day. Couple it with a shade for night time use. If the view isn't important and you prefer to not have a window shade, than a frosted or semi-opaque film could be used. Color recomendations, I'll leave that up to the stylists. |
