| Need counseling/advice, please. I'm am in the midst of remodeling 2 bathrooms. Two fiberglass tub/shower combinations pulled out and replaced by acrylic shower pan and tiled walls. My number one request was that I didn't want flex in the shower pan. Contractor said there would not be flex. Not in writing, of course. Silly me, so of course there is flex in the first shower pan installed. He set the second one in a mud base--no flex. Says flex in first bath is small and not really a problem. So, I went to shower pan instructions on line which clearly state pan should be set in mud. My question (finally!) -- is this a big deal? Will it cause problems down the road? What should I do? I've told him I'm not pleased with the flex but thought I could live with it. Should I make him rip it out and start over? Not a pleasant idea for either of us. Help! |
- Posted by aliceinwonderland_id (My Page) on Thu, Feb 21, 13 at 18:04
| With an acrylic pan? Absolutely, insist that it be installed correctly. Acrylic will stretch and/or crack under the stress of repeated flexing. |
| If the pan wasn't installed IAW the manufacturer's instruction, then yes, it's a problem. It could create a warranty problem should you ever have to go down that route. It can shorten the life of the pan due to the repeated flexing movement of the pan surface. It can create leaks around the drain, which can be one of the more common points of failure when pan movement occurs due to the drain/flange losing its seal, or the drain flange itself cracking. There is no telling if it will cause problems. If you haven't paid him in full, that money still in your hand is your best bargaining chip. I'd contact the manufacturer's tech department and ask if a non-mortared installation voids your warranty. Ask if it can potentially shorten the life of the pan. If it can make it more prone to failure and/or leaks. That's your next chip. I don't put much faith in a manufacturer's warranty. But you use what you can to bolster your position. |
- Posted by southboundtrain (My Page) on Thu, Feb 21, 13 at 18:21
| Thanks so much for some good advice. I will contact the manufacturer tomorrow. I haven't paid in full yet. I just hate this kind of stuff but guess this too shall pass. |
- Posted by Build-It-Once (My Page) on Fri, Feb 22, 13 at 8:45
| BE CAREFUL...mongoct is spot on. Subfloor can not have ANY flex. Mud, whether it's gypsum, cement or thin set will not make the flex go away. If it is one of those redi pans you tile over, be sure to check the warranty... i think it is only 2 or 3 years..is that crazy? |
