Sat, Feb 4, 12 at 15:14
| We're debating between tile and coni marble for our new walk in shower. I've heard that tile needs to be wiped down after every shower and cleaned often due to the grout. It won't happen in my house! What do you do to keep your tile shower clean?? |
- Posted by palimpsest (My Page) on Sat, Feb 4, 12 at 21:43
| We do actually dry the entire shower (white tile and grout) after every use. Initially it was a PITA, but honestly it takes under one minute and the shower has Never needed to be scrubbed, not once in two years. |
- Posted by mydreamhome (My Page) on Sun, Feb 5, 12 at 2:03
- Posted by bill_g_web (My Page) on Sun, Feb 5, 12 at 11:09
| If you tile, use a grout that resists stains; epoxy is the best but is more difficult to install; a tiler will likely charge more for labor. Laticrete makes a non-epoxy grout called Permacolor that is said to hold up well to residential use. I used epoxy grout and am pleased with the performance. Silicone caulk holds up much better than other caulks. BTW, a wetted dryer sheet really does remove water/soap spots from glass. |
