| I know this is not technically a bathroom, but it involves bath plumbing so I think you guys can help me. Our laundry room Here is a scale layout of the room currently. This is what I would like to do. The current 24" sink would be converted to a 34"x30" small shower/tub like in this picture. And for reference, the wall doors to master closet will be something like this. Now to the bath question. How do I go about converting the sink to a "shower"? What does it involve? DH is handy with carpentry but we would have to hire a plumber for this and I would like to have a handle on what the project would involve before I talk to a plumber. Forgot to mention: the area under this room is the mechanical room and the ceiling and walls are completely open there. Reaching the plumbing will be easy. And on the other side of the proposed shower wall is the master bath shower. Thank you! |
This post was edited by geokid on Wed, Feb 6, 13 at 14:08
| Can you get a toilet in there too? I'd like a toilet in a room like that. Also to save space you could put a pocket door at the entry. |
| Thanks for responding. I wish! But I don't think it will work. There is a powder room at the end of the hall. I should have said that the laundry room is not near a full bath. It is tiled all the way (the builder at least thought of that) but no shower within easy reach of the back door. I can handle messy footprints on the tile to the powder room, just not all over the house. :) Believe me, if I would have had input into the design of this home, the whole back area would be completely different. But it's too new to justify ripping everything out to make it how I want. Sigh. A pocket door is a good idea. Someone on the design forum suggested using a dog grooming tub. She used one in a similar situation and it looks like it works well. |
This post was edited by geokid on Wed, Feb 6, 13 at 23:35
| The sink to the shower should be relatively easy. The drain pipe would have to be moved and increased to 2". The washer may not be so easy. I would suggest cross posting this to the plumbing forum and add some pictures from the mechanical room showing the plumbing. |
| If the access to the master closet is only to avoid carrying dirty laundry into the utility room, I would reorient your plans and keep the washer and dryer on the wall where they are, stacked if you really want them to be, but at least you aren't having to rework plumbing and venting for the W?D. Take that counter and run it across the back from the corner toward the W/D, even across the top of the W/D if they are front loaders. Give yourself more work room instead of less. Instead of a tilt basket, create a mini door in the wall and use a basket on wheels. Depending on the room you have in your closet, it could be on the floor, above the counter, a push/pull thing or a revolving thing with two or more baskets. Consider your storage and other needs and make that space work for you. The dog crate can still go under the counter. I would make sure you still have the ability to do hand wash and hand washing in a sink -- either as part of the shower/tub area or a small separate sink. Plan for a rod, hooks or some other way to dry laundry or other drippy things over the shower. I think something along those lines would be less expensive and give you a lot more useful space. |
| Great feedback! I was just measuring in there to see if keeping the W/D in the same spot would work. The reason I wanted to move it in the first place was that I don't like having the W/D right when you come into the room. It's cramped at the doorway. Lots to think about. I'll get a plumber over here to look at everything and give me estimates on moving items. Then I'll know what I'm working with. But it's good to know my idea isn't unfeasible, even if it might not be the best option. I'll have to see. Thank! |
