Trouble Picking Shower Pan Material
Posted by Superman859 (My Page) on
Sun, Feb 10, 13 at 10:31
We are redoing our master shower (having someone redo it, anyways) and are trying to pick what material to use for the shower floor. Originally when we went tile shopping, we loved all the natural stone options (primarily marble), but after some research it sounds like this is high maintenance. Outside of the marble tile floors, we didn't really find anything we loved for tiling the floor of the shower with (we may still tile part of bathroom floor with marble, but not the actual shower floor). Ceramic and porcelain options are limited for small floor tiles needed in shower everywhere I've looked - mostly just white squares, hexagons, circles.
Now I'm thinking I should go with cultured marble for the floor. From what I hear, it is easy to maintain and should last a long time (no grout lines, leaking, etc). However, will cultured marble suffer from discoloring that marble tiles suffer from in shower floor when wet? For example, most people say the cheaper marble tiles have iron deposits which lead to rusting / yellowing of the tiles when they get wet. If this kind of thing may also happen with cultured marble, it sounds like it could still be an issue (just no grout line molding to deal with).
Ideally we would get a marble basketweave tile floor, but I don't think it's practical in the shower. We've only seen one or two basketweave options in porcelain / ceramic and they don't look anywhere near as good (although the ceramic carrara wall tile is a good substitute for the actual carrara). I think next to that, a cultured marble floor can look clean and fairly modern and have low maintenance, as long as it doesnt discolor due to same issues marble tile has.
RE: Trouble Picking Shower Pan Material
Have you looked at the cast iron pans? I think they go very well with the same types of showers (design-wise) that a marble shower pan would go with.
No seams, no movement or flexing when walked upon, it'll be ridiculously durable, all with what I consider to be an attractive and durable porcelain finish.
If you haven;t already ruled them out I recommend taking a look at Kohler's CI shower receptors.
Swanstone also makes a nice shower pan, it's less expensive than the cast iron, if you are doing a standard size shower.
Here is a link that might be useful: Swanstone Shower Pans
That photo of the cast iron looks nice, but I don't think we can go that route. I just browsed the Kohler site and it looks like it only comes in certain sizes. Our shower is about 4' by 5' (about a foot wider than standard), and I didn't find a match on the site. This may also eliminate the swanstone option. With the cultured marble, my understanding is they come out and measure and match the size needed.
Will cultured marble be very similar to the cast iron? Is maintenance on cultured marble tiles easy, or is it still high like marble tiles? Will it suffer discoloration that marble tiles inevitably get, or is something different about cultured marble?
I'd suggest taking a look at cultured marble somewhere, like Lowe's, where they deal in that custom shower base material. It is definitely not like real marble; it might be fine and attractive for you but make sure you see it first and like it. It certainly will be easier than installing a mud pan, shower pan, and tiling if you can get one made to fit your space. Dont' know if it yellows but I've pulled a lot of cultured marble vanity tops over the years which don't look so hot.
We just went through the same dilemma. We had real marble (12x12s) on the shower floor and they were in terrible shape. Marble is just not cut out for that kind of abuse. And with a weird shower shape, buying a custom iron pan wasn't really affordable.
While you noted that porcelain is limited, it doesn't have to be. The color selections are great. We chose the below penny-rounds. Hopefully they are going down in the next couple of days!
IMG_20130207_185824
I don't know if it expands your size choices, but one contractor suggested we look at silestone for a shower pan. They also make soapstone shower pans, again not sure what that does for you in terms of size.
You can also get a custom shower pan in any of the solid surface materials, such as Corian. They are fairly expensive though. Custom cultured marble would be less expensive than Corian, but may not hold up as well, although there are people who post on this board who have been very happy with their cultured marble showers. Here's a link to another thread.
Here is a link that might be useful: Cultured Marble Shower Base - good choice?
Superman,
I will answer your question about whether or not cultured marble has the same maintenance issues that marble does. NO, it does not! We had a cultured marble base custom made for our basement bathroom over 4 years ago, and after heavy use for that time, it still looks just like new. I went with a honed finish (not crazy about shiny cultured marble) and a very subtle white on white pattern. we had the walls done too, and an 8" wide shelf that continues on out of the shower the whole length of the room. It is not cheap, I have a quote right now for my master bath, and the 3' by 5' base will be ~$1100 before taxes, not counting delivery and install. I have never regretted our decision, this is our guest bath (but we use it now instead of our present pre-reno master), and guests have commented on it's being the nicest shower that they've ever been in! So, so easy to clean, no discolouration whatsoever, I squeegee the walls after my shower, and every once in a while wipe with Method cleaner and a microfibre cloth. the squeegeeing may be unnecessary, but I'm doing the glass walls anyways, and I figure less water sitting around in the basement bathroom... is a good thing!
I'm also considering a terrazzo shower pan, having seen one on Houzz. Does anyone have any experience / thoughts on terrazzo shower pans? They seem to have more size options than cast iron or swanstone (NOT Veritek), both of which are also in the running. We have a Swanstone showerpan in the kids' shower and it's been great, very easy to keep clean and looks good. But they don't seem to make it in the size we want, ideally, for the master bath.
Here is a link that might be useful: Terrazzo showerpan on Houzz
We had terrazzo floors when I was a kid, kitchen46, and one of our favorite things was to run and then slide like crazy on a rug or towel down the hall, and to watch the dog trying to make fast turns, which made him look like a cartoon character as his feet kept going one direction while the rest of him turned. It's very slippery.
