Sat, Feb 9, 13 at 9:35
| Hi, I'm in the process of rebuilding a bathroom. As part of the remodel I cut out the sofit which means the bathroom walls and ceiling have to be re-plastered. Any suggestions on the best plaster finish to use? Orange peel? Knock down? a hand applied higher relief? or something else? What is left of the existing walls is a knockdown but I can change it to anything. Thanks in advance. |
- Posted by live_wire_oak (My Page) on Sat, Feb 9, 13 at 12:33
| Smooth is always best. |
| I always vote smooth on wall texture. |
| Thank you for your thoughts. I will probably use a knock down given the more humid environment of a bathroom. It will be much easier to clean. |
| Just curious, why would knock down be easier to clean? In my experience the easiest surface to clean is always a smooth one. Dirt collects in the indents of a non-smooth surface. |
| Smooth. But I am assuming you feel you are not able to give a smooth finish DIY? We did our kitchen ceiling, and though I did end up having to go to a massage therapist (stiff neck), LOL, would do the bathroom that way again for sure! (much smaller area, and so much easier to wipe clean!) |
| Anything except smooth is a PITA to clean. It tears up the sponges and dirt just loves to hide in the texture. The only way to clean texture is with a suitable brush to scrub. |
