Tile Masters Help Please! Mix AO & US Ceramic Tile
Posted by southerngalinnyc (My Page) on
Sun, Feb 19, 12 at 8:53
Happy Sunday! So I am frugaling out on my hall bath. HD has US Ceramic Matte Subway Tile for under $2/s.f. and AO is over $4.40 s.f. Problem is of course that I need a chair rail and US Ceramic doesn't have that.
AO is .315" thick and the US C is only .25" thick.
Can I mix the AO chair rail with the USC tile even if I am putting the subway tile both above and below the chair rail?
Also... (trying to sneak this one in...) If I am tiling to the ceiling in the shower and one adjacent wall and want to use a crown molding All the way around the room, but am planning to tile only to the height of the chair rail on the sink wall... how the heck do I handle the transition? Do I simply butt the crown molding against the tile edge?
Many Many Many thanks,
e
RE: Tile Masters Help Please! Mix AO & US Ceramic Tile
If the chair rail is glazed on both the top and bottom edges, it shouldn't be a problem. Line them up next to each other, just as they would go on the wall, and you'll be able to tell how it looks. Sorry, I don't understand the problem with your second question. I can't see how the chair rail affects the crown molding. Perhaps a sketch would help.
As far as your second question, in my prior home we had tiled our shower to the ceiling and put in crown moulding in the room. My GC put crown all the way around including the shower. He used an extra piece of wood for the crown not over tile so the ultimately they were the same depth. I hope that makes sense.
Are you talking about the raw edge of the chair rail when you end it at the start of the full wall field tile in the shower? Can you miter a piece of rail to the end and then start your shower field tile next to the new rail finished edge? It would be a tiny mitered piece I would imagine but would finish it off wouldn't it?
You can either use the AO chair rail, or use a painted wooden one. Either would look just as good.
Many thanks to all! I will go with the AO chair rail since its running through the shower also and use the extra wood underneath the crown to solve for the depth differential!...
Unless of course I change my mind for the millionth time... maybe beadboard instead of tile...
