Shower Niche - How to Tile?
Posted by BlackChamois (My Page) on
Wed, Jan 4, 12 at 20:48
I am installing a niche in my shower.
I am using a white subway for the field tile. The sides of the niche (inside the niche) will be the subway tiles also, but on the back of the niche I am doing a "mosaic" effect with penny rounds.
My question is ... do I lay the side tiles first, and then the penny rounds? Or the penny rounds first, and then the side tiles?
I know it may sounds like a trivial detail! I am inclined to say the former ... side tiles first, then the penny rounds, but would like to hear from the experts! Thanks much!
RE: Shower Niche - How to Tile?
It'd look much better if you do the penny tile first. They're a little tough to cut straight, and have a tendency to fall off the sheet if you cut them on a wet saw. Installing them first means you don't have to be as precise with your cutting, because the side pieces will hide the cuts, thereby giving you a much cleaner look.
post Script
now-- I hope you've waterproofed this niche, and about 6" out onto the wall all around it??
Thank you for the info on setting the tile! I've seen some advice to use Redguard. Is that what you would suggest?
Either that or Hydroban.
