oollaam
Tile does not extend down enough around bathtub
oollaam
I have incorrectly installed tiles around bathtub. Tile is only about 1/8" below top of bathtub lip. I now realize that it should have extended to about 1/8" from the tub surface, but it is too late...
Water barrier and duralock has been used behind the tiles.
I planned on using silicone and sealing well behind the tile and creating silicone ridge at 45 degrees to the tile so that water flows away from this surface.
My question is, do you think this approach will work? Do you have any other ideas what can be done?
Comments (2)
