Our New Master Bath
Posted by estherclee (My Page) on
Fri, Feb 23, 07 at 14:55
It all started with a little leak.
One day we noticed that the carpet around the shower was soaked with water. I ripped open the area and discovered that water has been coming out of the corners of the basin. Good thing the leaks didn't damage the floor nor the ceiling underneath.
The house is just a little more than 10 years old now, so it's probably not out of the question to have this happen.
We first re-grouted the tiles but the leaks continued. So for a cheap fix, we just corked all over the inside to plug the leaks.
We were going to replace the carpet with vinyl flooring. We didn't want to go tile thinking it would be cold and too expensive. But after getting quotes from a few places, we were shocked to learn that vinyl would cost almost as much as tile. So after looking at the options, we decided on tiling the floor.
The original bathroom was not too dated. It had standard white tiles and framed plastic shower enclosure. The walls were painted white also, so it was a very "generic" bathroom.
The tub enclosure had a fairly large surface area, and we used it for our plants and other nick-naks. With the remodel, I wanted a sitting area inside the shower, so we decided to extend the new shower onto the tub enclosure also.
We also decided to upgrade to a frameless glass enclosure to match the new tile work.
The crew turned out to be the owner's sons and their friends. They did a good job building the base of the shower. That was probably the most important part of the project.
They completely took out the tub, which is the right way of re-tiling around it. They replaced the wall boards with the moisture resistent type, which is something that should have been there when the original builder constructed the house.
In general, the crew did a good job. However, since there were so many individuals working on this project (we saw a different person everyday coming to the job), and the fact that they didn't communicate with each other very well, we ended up with many instances of re-work because information was not passed on from one crew member to the next person working on the same task. They were responsive in fixing the mistakes, just wished we didn't have to go there.
Another goof-up was re-installing the tub. Somehow, it went in crooked. It also made this noise when you stepped inside. Apparently, the foundation was not quite right. One of the faucets was also misaligned. When we showed it to Dave, he had the crew completely remove the tub and re-set it again. They did it right the second time and everything is correctly installed.
It was frustrating to have these goof-ups, but they quickly fixed them to our satisfaction. So overall, we were pleased with how the remod turned out.
The project took almost 2 months to complete. We really love the new look. It's amazing how much difference a little more room in the shower makes. The new tile floor is not as cold as expected, and certainly a better value than laying down plastic.
The glass shower enclosure added a more modern look, and better quality than the old plastic one. We also love the travertine basin and trims. They really complimented the entire design very well.
It's a great bathroom...and it all started out with just a little leak. We hope this will be the last home improvement project we'll do for a while.
Here is a link that might be useful: The New Bath
RE: Our New Master Bath
esterclee - what a pretty bathroom you now have! I love the travertine on the shower floor. Are the borders travertine as well? What about the wall and floor tiles? My master bathroom is very similar to yours. My remodel starts tomorrow, and I've decided to eliminate the tub completely (never used it in the 4 years I've lived here!) and extend the shower out a foot. I've been dreaming of travertine on the walls but am thinking of compromising with porcelain.
Ann
Hi Ann,
There is travertine on the borders, the ledge of the edge of the shower and the little cubby for soap. The floor and the wall were ceramic tile. We wish we could afford an all travertine bath, but since we had the lighter ceramic on the wall, it made the decorative stuff stand out more.
I also thought about removing the bathtub (1 use in 3 years), but was to chicken cause of resale value. The only thing it was good for was holding my potted plants during the winter.
I'm really enjoying my bath. And from my experiences with our contractors, I have to say, never assume nothin'! What they have in their minds may not be what you have in your mind.
All the best and please post those photos when you are done.
Esther
Thanks for the additional information, Esther. Can I ask where you got your soap holder?
Ann
Opps I forgot. The soap holder is travertine too. It was expensive for us ($50), but it was the only thing that would look right. We got it at The Tile Shop. Here's a link to their page: www.tileshop.com.
Thanks Esther - I'll see if I can find something like it where I live (California).
Ann
