| Since there a lot of Liebherr owners here, wonder if someone can tell me what the amperage is of the 30" models. I have ordered a CS1611 but assume all the CS 16 series use the same amount. I know it needs a 15 am circuit but I don't see what it actually draws when running. I am replacing a 1984 SZ that used 6 amps. Since I don't have a dedicated line I want to make sure I am not overloading the circuit. |
| I don't own a Liebherr, but like my Jenn-air 48" fridge, it does use the variable speed compressor/s,--mine has one, yours has two. These type of compressors do not take the huge "Start up Current" that conventional On/Off compressors do and many SZ's used the old (On/off) style compressors not sure about the model SZ you had. The startup of the old compressors is what really draws the power, and then the old styles run at full RPM, whereas your Liebherr runs at variable speeds, usually slow unless more cooling called for (door left open a while, fridge set for a lower temp, etc). I would recommend you stick with Liebherrs recommendation as far as power goes, A Dedicated 15 amp circuit, However I did manage to find this: CS 1611 I'm not positive what that 2.5 amps is, could be per compressor???? Best thing would be to call Liebherr. Looks like you made a great choice (At least until we hear about SZ again using Variable speed Compressors, LED Lighting, etc etc---)!! A "Kwik way" to compare the power draw of the SZ versus the Liebherr would be to find the energy star rating of your old SZ, is it more than 431 kWh?? If so, the the Liebherr uses less power than the SZ, HTH's!!! Gary |
