| I have an old 24" wall oven in a 27" cabinet that I've wanted to replace for 6 years. I found an older model Gaggenau EB290 in good shape but am concerned that the width won't fit into the cabinet. Looking at the specs, it needs a cut-out width of 26", so I'm guessing the frame will overhang an inch on each side of the cabinet, which is not ideal :) I may fudge it, though, just to get this oven. Would anyone be able to confirm this as I can't get up there to measure any time soon. |
- Posted by live_wire_oak (My Page) on Wed, Dec 19, 12 at 16:35
| Depending on the cabinet construction, a 27" (exterior dimensions) oven cabinet may only have 25 1/2" to 26 3/4" interior room. You need to pull the old oven and measure the interior, as well as how much actual face frame can be trimmed. |
| "so I'm guessing the frame will overhang an inch on each side of the cabinet, which is not ideal " Why is this not ideal? In Europe a 27" oven gets put in a 27" cabinet all the time - it is very IDEAL. It's actually 70 cm , but let's play inches for the sake of brevity here. Your cabinet is either 27" wide or it is not. If it is , the oven will fit. How much modification to the existing structure is needed is anyone's guess. "Would anyone be able to confirm this as I can't get up there to measure any time soon." What, exactly are you looking for confirmation on? Yes the Gaggenau 290 needs a cutout width of 26" minimum. As for confirming what your cabinet is - no one here has any clue as to what you have. |
| Good heavens, I wasn't asking about my cab. I was asking about the actual width of the oven. I've seen 27, 27 1/8, and 29 inches from various sources. If the front panel is 29, then I wonder if I'll need to address an overhang. I guess my title was ambiguous. Is the EB290 27ish inches or 29 inches wide on the front panel? |
| Thank you Live Wire Oak, looks to be just 26" interior room. It would be a snug fit. The cab's actual outside measurement is 27.5". I just prefer that the oven frame not exceed the cab's width by an inch and a half and wasn't sure if the sources that stated it was actually 29" wide were correct. |
| The oven face is actually 690 mm wide , which is just a hair under 27 3/16" wide. |
| Thanks! |
