Sun, Dec 23, 12 at 9:15
| model w10142800b.4yrs old,already replaced control board 2 yrs ago,then the key pad just 4 mos ago.I have no lights.Went through the kill power,power up n try the keypad routine and nothing.Then opened it up,I have power through the thermo fuse jobbie but nothing to either door switch.Unplugged each switch and both are goog.Also jumped the float hoping that might be involved.All connections checked.stumped.Help!I have a multimeter n circuit test light.Could this be the the control board already? |
| I see this has been up for a while with no responses here. I suggest you post this in the Laundry Room forum where there it will likely get a faster response. |
| Of course the control board could be the fault. Trace-out the wiring diagram for what other components may be involved, but likely power to everything goes through the board first. |
- Posted by Jumpilotmdm (My Page) on Sat, Dec 29, 12 at 16:45
| Sounds like the board to me. Looks like you've checked everything else it could be. Throw a pitcher of water in it and try it before you buy a board. |
