Question or those of you who use a gas Infrared oven broiler
Posted by Madeline616 (My Page) on
Fri, Dec 9, 11 at 9:04
Hello,
Really glad I learned about the infrared broiler in AG ovens, before deciding on my new range. I'll finally place my range order today or Monday for either Wolf or Viking 36" AG open burner.
I have a couple of questions.
I cook fish (everything from cod and halibut to thick sea bass and tuna steaks) very often, on a cast iron pan on the stove. I heat the dry pan for a few minutes on high first, sear the fish, turn it down to med or med high, flip once, and voila, it turns out perfect every time.
But it creates a lot of smoke (plus my hood vent system desperately needs replacement).
My questions are:
Is charbroiling as "smoky" of a process as searing and then cooking a piece fish (or steak)?
How quickly does your broiler heat up? Is it practically instant, or is there a wait time?
Finally, if anyone has experience with Wolf vs Viking AG infrared charbroiler (or open burners) that would be helpful.
RE: Question or those of you who use a gas Infrared oven broiler
I have a CC but I'm sure they're all very similar. It takes about a minute for it to light and come up to broiling temps. Basically as long as it takes for the glow plug to get hot. I usually fire up mine as I'm preparing the food for the broiler so it's ready when I'm ready. I think one time I fired it up as an afterthought, and I waited a couple of minutes anyways to let it get good and hot. I didn't actively monitor it. I just turned away to do something else and came back to it. But it was ready so it was a non-issue for me. My range vents out the back, so smoke from broiling has not been issue. I'm sure the Wolf and Viking are similar in this regard.
One thing an IR broiler does not do well is blackening. For that, you'll still have to use cast iron and deal with the smoke.
I have a Wolf in my own home, the gas broiler heats up within a minute. Very satisfied. I don't broil fish, but I do broil steaks in there all the time and the come out just as good as they would on the grill.
I would definitely recommend either the Wolf or Viking. The Viking does have a glass enclosed broiler which is a bit prettier and easier to clean, but overall no different in cooking ability.
Hope that helps,
Anthony
Appliance Buyer's Guide
We have a Viking. That broiler REALLY gets hot.
I have the Wolf AG. The infrared broiler gets plenty hot. No preheating is needed per the owners manual. Just slide in the food and that's it. I love mine.
I have AG Viking. I use my infrared broiler quite a bit. I really like having AG oven. I installed a second electric oven rather than replacing the AG with dual fuel. The smoke gets sucked out the back as stated above.
You get different type of finished product if you cook on a super hot cast iron versus under a broiler. The taste of cooked on 'fat' (ie cast iron pan method) cannot be copied without adding direct fat. This has to do with how 'fat' is cooked onto the food. Your fish will taste quite different in those two cooking methods.
I also have an infrared broiler on an outdoor gas grill just outside which is used as a rotisserie. I tend to use the outdoor BBQ with infrared broiler for smokey stuff:)
Thanks for the responses. Love the first-hand experience. Can't wait to get the range and get started!
