sub zero column help!
Posted by azheng (My Page) on
Fri, Nov 2, 12 at 22:12
Hi,
I'm interested in buying the BI 36R and the IC 27 FI refrig and freezer columns from sub zero. the refrigerator is a built in unit, and the freezer is an integrated unit. If I put wood panels on them, will they be noticeably different if i put them next/near each other, besides the top section of the built in refrigerator (the grill)? (such as the actual door height)
RE: sub zero column help!
If installed correctly the fully integrated will sit flush with surrounding cabinetry.
Built-in will stick out about 1.5".
The top of the door for the BI is 73 3/4" while the top of the FI model is 78 9/16.
You can see all this information in the Sub Zero Design Guide linked below.
Here is a link that might be useful: Sub Zero Design Guide.
thanks!
