Changing a 30 inch cooktop
Posted by drewem (My Page) on
Thu, Nov 15, 12 at 14:09
The new house will have a 30 inch KA gas cook top, with 600 cfm range hood above.
The base cabinet supporting the top is 36 inches.
In the future could I change out the top to a better one, for instance a 36 inch wolf, 6 burner?
Besides having the granite re-cut, is there anything else that needs to be done? Or is this just a dream? Adding it in now is out of the budget.
Thanks for your responses!
RE: Changing a 30 inch cooktop
The difference between a 30"and 36" KA is only around $600. Cut something else.
If you did, the hood would be too small.
I was wondering about that weedmeister. I did see that in the hood specs it stated that a 1200 cfm fan motor could go in it. Builder is putting in the 600, so maybe in the future I could switch the motors out?
Thanks holly, I'll consider it, but the builder is charging an arm and leg for options so I think their mark up will be more.
Or, I could keep the 30" size, but change it out to a Bosch 800, a little while later. According to AJ Madison the Bosch has a cutout width of 28 15/16" and depth of 19 1/8".
The builder included KA has a cutout width of 29" and depth of 19", again according to AJ Madison.
Would that fit?
The issue with the hood isn't the CFM - it's the width. A 36" cooktop needs at least a 36" hood.
I just checked, it is a 36" hood.
Would the Bosch fit in the cutout for the KA? The dimmensions are above. Thanks
Bosch 30"w induction cooktop cutout is 28-3/4" x 20". Extra 1/4" depth probably not a big issue but you'll need to expand chop an inch of depth to make the Bosch fit.
Their gas 800 cooktop needs a 28 15/16" x 19 1/8". It may squeeze in to your existing hole.
