| Gary,
I have Valor-related questions, and since it is a "heating appliance," I hope it's not too off-topic to post here... ;-) I would've emailed, but your member page doesn't have that option. I have read how happy you are with your Valor and that it heats 2700 sq ft. But you never share what model it is, and I was hoping I might get that from you, and maybe how you decided on that one. I've been looking on their website, but am confused about where to start and how to narrow down to what we need. The nearest dealer is a ways from me and I want to do some research and have ideas of what I might want before I am at the mercy of a salesperson. Our home is also about 2700 sq ft. Since it's 2 story, we might want something smaller than yours, though, so as not to be blown out of the main floor? Thanks! |
| Glad to be of Service! (Nothing worse than being at the mercy of a salesman)!!! First question, Are you on Natural Gas or LP? The model Valor fireplace that I have had (Over 5 years now) is the Valor Horizon Series (534 xan). http://valorfireplaces.com/media/pdfs/brochures/Valor_Horizon_Brochure .pdf Here are some of the threads about Valor fireplace that are in Garden Web. http://ths.gardenweb.com/forums/load/firepl/msg1019041427827.html http://ths.gardenweb.com/forums/load/firepl/msg0800001523200.html http://ths.gardenweb.com/forums/load/firepl/msg1208372219414.html?10 http://ths.gardenweb.com/forums/load/firepl/msg021447401240.html As you will see from these posts, I'm my "Usual self" (IE quite chattie or should I say "Typie"? But I try to cover "All the bases" as far as info about the Valor. The model I have has been replaced with this one. http://www.valorfireplaces.com/media/Horizon 2009/horizon_brochure_w eb.pdf More that likely You will be told I think I have "covered all the bases" both here and my previous posts and if you have more questions, you may post them in the fireplace forum (If you like) as I visit that part of GW on a daily basis. Good luck in your hunt, I hope you will be as satisfied with your purchase as we are, )_even after more than 5 years now)! PS Actually it is good you posted about the valor here in the "Appliance Thread". That will keep me too busy to do any more "Creative Writing" about Miele ovens and "Ticking Off" Gary
| We don't have NG available to us, so it'll be LP. I read those posts before I posted here. ;) I was just wanting to see how the BTUs your model has compares to the BTUs recommended to me when I use their calculator. If I can't turn it down as much, I may want to be conservative on stove size? That is great advice about the fan since Valor claims there is no need. In one of those past discussions you linked a shop that listed prices. For estimate's sake, I priced an H4 model, which with the fan totalled nearly $4K, so my dh just laughed... I don't think that's a good sign... :-/ Thanks for your kind help! And behave yourself on those oven threads. :-D |
| The H4 has about the same specs as mine, EXCEPT, as I mentioned, the H4, like mine will only turn the heat about halfway down when used with LP. Most of the reviews I've read, where folks said they wished they had bought the Valor instead of X or Z, their complaint was the fireplace did not put out enough heat, not that it put out too much. There are NO Valor fireplaces, that I found that will turn down below half (Using LP), and I would have to do some searching to find if indeed there is such a gas fireplace, made by any company. When I was pricing fireplaces back in 2006 or so, 4 grand seemed to be about the price by the time everything was said and done, unless I looked at some real "Cheapies" which would probably only decorate and not heat a room. Gary |
| GOOD point. |
| I second dodge on the fan kit. I was told by the salesman that it only increaes efficiency by 3%. Balogna!!! I wasnthrilled with my valor before the fan kit. |
| Thanks for your input, too, tyguy! |
| You are very welcome rhome. One of the nice things with valor is that their zero clearance models can be vented co linear as well as the traditional direct vent. (I needed co linear) |
| Thanks for taking the time to add the extra info. Does that mean you vented vertically through an existing chimney? I don't have one, so will need direct-vent. |
