| So I've seen this question presented a few times, and the answers seemed to only kind of gloss over everything without giving a comprehensive review of the unit itself. I wrote this in the other forum, but I figured it would be more relevant and better archived in here.
I have had my 36 inch 5 burner Bertazzoni gas range for almost two years now. I can safely tell you it's an awesome cooking machine, but as with any range it has ups and downs which I will try and relay to you. First, the burners are awesome. They light easily and burn with a really smooth clean flame. I love the layout of the burners as well. I find myself using the front left burner generally the most. I do use the center burner occasionally for big pots and such, it has great power, but in reality the tiny 1 inch center inner ring burner doesn't really make sense to me the company should have just made it one burner complete burner instead. The control of the burners is pretty great, and the low settings can go very low on the smallest burner (think melting chocolate or something without burning). The other feature I really like about the burners is that they can be manually lit, which as of this past week was a godsend since I didn't have power. The burners are the best feature on this range by far. They are easy to operate, and super easy to clean. Secondly, the oven. Now, this oven is great for flatter dishes like casseroles and stuff. It can handle things like a turkey and what not, but this oven is obviously wider and flatter than some other ranges. This is due to a design where there is a fold down cabinet below the oven. Part of me wishes they had just done away with that storage space and made the oven taller. This I feel like is the ranges biggest limitation, fortunately for me I have a wall oven as a supplement. The oven is very even, but it does heat up fairly slowly, and there is no thermometer inside the unit so you'll have to put your own in. One quirky thing about the oven is that it has a "fan failure" light, which seems pretty weird, and mildly worrisome that a manufacturer decided to put a failure light on it. The oven also CANNOT be lit manually, I tried and tried, you can get gas to come out into the oven, but I believe the temperature gauge is electronically controlled. Just an FYI the owners manual says you should NOT attempt to do that, it was a desperation attempt since my power was out for days due to hurricane Sandy. The build quality is very good, I really enjoy the fact that the burners can be removed and there is a single pressed stainless top to it, making it extremely easy to clean. The oven however is not self cleaning, and requires some elbow grease (or have your maid clean it if you've got one ha ha ha). Another oddity of this range (which my friends have now learned to deal with) is that the burner knobs need to be turned "downward" to turn them down. It's not a big deal once you realize how it works, but it's funny to see someone who has never used this range before try and turn the burners down. If you're not understanding my point, the burners don't go left to right, the highest setting is 90 degrees to the left and straight down toward the ground is the lowest setting. Now, the reason I purchased this range over the other options were as follows. I am not by any means a professional chef, I cook for myself and entertain a lot, but I didn't need 22,000btu burners and stuff. I wanted something that just worked, and looked nice doing it. I also thought the price point seemed much more reasonable when compared to the 'high end' brand names. I also picked this because my friend owns a Viking range and it has been absolutely nothing but trouble. I went out on a limb buying this range, and the bert wall oven even further since I couldn't even buy that through my local Bertazzoni rep, I ended up getting it online. I wanted something unique and I think I got that. It's also a plus that the oven was built in Italy. However, there are some serious drawbacks with this range. Minus the oven stuff, there is one thing I am very concerned about, which is that there is no way to lock the burners, especially the oven burner/ignite switch. People tend to lean in this area of my kitchen and it's happened so many times that someone will bump their butt into the gas on oven on switch. This causes the range to start ticking and it freaks people out, it also starts the oven releasing gas. The burners also cannot be locked *they need to be pushed in but only a cm or so to allow them to be turned thus releasing gas*, and they are very easy to move and operate (a plus for the chef) but a major downside when my 2 year old niece is around and pushing buttons on everything in my kitchen. I wish to death that the range had a lock feature for these. My old Jenn-air needed to be pushed in and down to unlock the burners, a design which I felt was much safer. Another upside/downside depending on how you look at it, is that the racks inside the oven are exceptionally heavy, these are by far way too overdesigned. They probably weigh 8 pounds each, which means they won't bend ever no matter what you put in there, but moving them in and out of a hot oven is going to require two people with mittens. The oven when operating also blows warm air into the kitchen, which in the winter is amazing for me, but in the summer it's kind of a drag if you're cooking something for 3 hours, it'll heat up the kitchen space by a few degrees. I also see now that Bertazzoni is offering a stainless griddle that can be rested on top of the center burner, or burners depending on the model. I wish the company had included that with the unit, as it does seem nice to have. And I'm a little iffy about spending the $375 dollars to have such a small griddle, even though it is matched to my range. Overall, if I had to buy purchase a range again, I would choose bertazzoni over the other brands. The price simply cannot be beat for the features you get, I think I got mine for $3,100 and the next comparable pro-style range was $6,000+. People automatically assume it cost much more than it actually did ha ha. However, if I were to do a remodel again, I would have gotten a larger range but unfortunately bert doesn't make a 42 inch, the next biggest size up from 36 is 48inch, so I settled a little. But it performs just as well as my friends Wolf and Viking on the burner front, which is what I use it for the most anyway. It looks beautiful in my kitchen, and it's a good conversation piece since not many people have seen this brand before. I have the feeling that in the next few years this range will go up in price. I think Bertazzoni is a "budget pro-style range company" but I believe with the continued popularity and the presence in high end installations, their price will gradually increase. I saw that the 48inch model is currently (2012) priced at $8000. I would not be surprised if next year the 48 inch model is $1000-1500 more, and the 36 $500 extra or more. Hopefully I am wrong, because this is a great (nearly amazing if only the oven was taller) range for this price point. I hope this review helps anyone who is considering purchasing this range. Here is a photo of my beautiful range in my kitchen! |
| Thanks for the detailed review. I am also looking at the 36 Berta and I have a few questions: -How did you find cleaning the burners and the range top? -Any problems with the simmer burner, can it hold a low temp? -Any issues with the oven and the fact it only goes down to I believe 275 -Is the build quality up to par? Thanks for sharing. |
| It appears the Berta gas ovens on their ranges now shipped to the US no longer have manual ignition capability. The units sold in UK seem to be all dual fuel only. |
| poolmy: it is exceptionally easy to clean. You just pull the grates off, then the burners and go for it. I have not had any problems with the simmer function, it works as advertised, and I have made things like hollandaise sauce on it. The oven does only start at 275, but for me it's not a problem since I have a electric wall oven. There may be a bertazzoni model which comes with gas top and electric oven. The built quality is great. I have no complaints about the thing, the grates are awesome and heavy, the stainless pressed top has no dents or dings, and the oven door is pretty heavy. Hope this helps. |
| Having dodged two potential electrical power failures in the last two weeks (Hurricane Sandy and Nor'easter Athena) I am absolutely uninterested in gas ranges that cannot be ignited manually. This is simply a showstopper. |
| jgopp: nice review.
inox: Not sure I get your point. Are you asking if the Bertazzoni's can be lit manually? Ifso, then, yes, the stovetop burners can be lit manually AFAIK, with the current model Bertas, like most stoves with any kind of thermostat, you cannot manually light the ovens. From other postings here, I gather that there is Berta model somewhere whose oven that can be lit manually but it works like a gas bbq grill). OTOH, if you are saying that you want a gas stove that can run totally off the electrical grid, then you want to look at stoves other than Berta or just about anything else discussed here. There is the bottom of the line Hotpoint (it uses a 9v battery), a company called Unique Gass Stoves for Off The Grid Living (also uses 9v batteries and can be found in Backwoods Home Magazine and at Lehmans website), and Peerless Premier (some reviews here but mostly bad, and Costco stopped carrying them after a lot of returns). Or look for an old pilot-operated a gas stove from fifty years ago and put up with the old style ovens. Or look for an AGA cooker. Or, look into tiling your kitchen, installing MUA anda fire-supression system, and check out a commerical stove. If you are in any of those markets, you are absolutely uninterested in the Bertas discussed here. |
| Great reveiw. We purchased the 30" gas Bertazzoni approx 4 months ago and have really enjoyed it. I love the look, how flush it sits with my cabinets and how well it compliments our Liebherr fridge and F&P drawer dw. The simmer works well on ours and it's reasonably easy to clean. Love the burner with the inside/outside flames for when I need to boil a pot of water quickly. Almost didn't get because it only goes down to 275, but I've been able to make meringues and granola without too much trouble. I also use it to keep plates warm just by heating to 275 then turning off. Build quality seems solid and as hoped. Drawbacks for us are the heat that it kicks out in the Summer. We cook a lot and it's probably 10 degrees warmer in the kitchen at all times when using the Berta. The burners also seem to cook much higher than our previous range so still getting used to it, but not a problem with the unit itself. Would agree on the lack of locking option, but I do like that the front of the oven does not get hot to the touch. Finally, the fan noise when you turn on the oven is a bit louder than I would like. Doesn't bother my family but I definitely find it more challenging to hear what's happening in the other room. However, I would pick it again and if they would have had the option for yellow in the 30", I would have gone with that! |
| jgopp: Fantastic and very comprehensive info. Thank you! And your kitchen is beautiful. When is your next party? :-) lqofhb: We are just about to purchase the 30" gas Bertazzoni range and convert it to propane (natural gas isn't available). Based on the earlier posts, I am unclear as to whether or not all of the Bertazzoni ranges can be manually lit without needing electricity in the event of a power outage. Have you checked this out? Thanks so much. |
- Posted by janicedallas (My Page) on Wed, Nov 21, 12 at 14:05
| I love my 30" range. However, take your favorite large pan and see if it fits because the oven is configured smaller than most American ranges. The burners, the knobs, the cleaning, roasting chicken are great. EXCEPT the oven gets too hot and I can't regulate it. I have found it is just not doing my cookies and cakes as I would like it to perform. I called customer service and she told me to bake some crescent rolls and that was their test. The crescent rolls were fine so I'm now at a loss. The simmer burner is a little too high but I am okay with that. |
