JOIN NOW LOG IN
Tips for Miele oven owners from our Miele service guy
Posted by monaw (My Page) on
Sat, Nov 7, 09 at 0:13
First of all let me say that we have had our double ovens for one year and our experience with Miele service has been top notch.
We had a guy out here yesterday to look at the tubular mesh seal. It was hard on the bottom part and we were concerned. Turns out that the seal is only there to protect the door from rubbing against the oven itself....it was fine but he replaced it anyway in seconds. I asked him several questions. Without writing a book here, the following is one bit of info that I was really glad to hear, and had I known this, I would have gotten the Miele ovens that were not self cleaning.
He said "Never use your self cleaning program unless it is an emergency".
In other words, unless it is so bad you can't clean it yourself. He said that it is better to use Easyoff than it is to use the self clean cycle.
There are two reasons. #!. The oven gets so hot when it's on clean cycle that it's not good for the computer board,...especially if you open the oven before it has cooled way down. and #2, it's not good for the enamel on the inside,...causing it to expand and contract and eventually over time crack. He said it's better to wipe it out after a messy bake, and to use Easyoff oven cleaner rather than the self clean cycle. I asked him about the "Easy clean" surface and if Easyoff would damage ....etc. He insisted that it was better not to use self clean if you can help it. I have had the ovens for 1 year and cleaned the top one twice. It did get very smelly. He said what we are smelling has a lot to do with 1000 degrees and what happens to the enamel.
Just wanted to pass this on...
RE: Tips for Miele oven owners from our Miele service guy
I have had the Perfect Clean Miele ovens for 3 years. I clean them with Greased Lightning and a green scrubby. I have also used baking soda. I can not imagine any time that you would need to use oven cleaner. Also I can't imagine what MY ovens would look like if I had only cleaned them 3 times in a year LOL. I clean them after every single use except if I am baking bread in a pan or a cake etc where there is nothing escaping . If I am baking/roasting or using the rotisserie I always spray a light coating of GL on the surface of the oven and then wipe out with paper towels after it sits for awhile. Usually everything comes off and you have brown syrup on the towels. If there is something more then it gets the "extra" scrubby and spray or of it is really bad then it gets the "baking soda under a cloth towel with boiling water on top treatment".
One key thing to remember is never let your ovens cool with the doors closed if you have baked messy stuff in the oven. All it does it bake it on more as the ovens cool slowly. Go ahead and get that door open and get it to the point that the fan is off. Then immediately spray on the GL and close the door and finish doing the dishes and then wipe out the oven. Voila...pretty as the day they were installed.
Oh you can also use BarKeepers Friend on a tough spot. Also always put a small amount of water in the drip pan under the roasting meat or in the rotisserie pan to prevent about 75% of the splatter. Hope this saves some of you some work and time and gets your oven back to Perfect Clean ! c
I have have had my Miele oven for two years. I had my previous self-cleaning oven for 25 and could not live w/o the SC feature. If I had to go back to scrubbing down the oven after "breaking the bank" to buy the Miele, I would be one,very upset customer.
I yet to have any service reps tell me not to use the the self-clean function, nor do I recall reading anything about this issue on these boards. I do thank you for passing this info on, but I think I'm going to take a chance on this one!
Many (if not all) self-cleaning ovens instruct owners never to use oven cleaners, e.g., Easy-Off, or abrasives as doing so will harm the self-cleaning components. How can manufacturers sell self-cleaning ovens and tell you not to use them? Isn't that akin to fraud?
I'm simply amazed by the bizarre information people relate as having been received from their service people. All I can say is, don't believe everything you hear. Service people can come up with some pretty off-the-wall stuff.
In my estimation, if Miele didn't think their ovens were up to the rigors of the self-cleaning cycles, they'd either stop selling them, or they'd figure out a way to make sure would withstand repeated use of the cleaning cycle. I just don't know how these self-appointed service gurus come up with these strange theories. What rubbish!
Personally, I've never liked self-cleaning ovens. I find the fumes generated during the cleaning cycle to be rather noxious. I chose to go with the Miele PerfectClean ovens. I clean up any major spills as they happen, but other than that, I wipe out the oven on a fairly regular basis, scrubbing any stubborn spots with a little Formula 409 and a nylon scrubbing pad called "Dobie". After 4-1/2 years, and almost daily use, my oven isn't as pristine as it was when new, but it looks very good. I wouldn't be embarrassed to have anyone look in the oven. The door glass is still perfectly clean, although it sometimes takes a little elbow grease to keep it that way. The non-stick coating that Miele puts in their PerfectClean ovens seems to work very well, and is quite durable, although I'd never use anything as abrasive as a green scrubby. I've had very good results with the Dobie pad, and recommend them. You can find them at most supermarkets.
Probably from experience of having to repair the ovens :-) I agree that it's a bit outrageous for manufacturers to sell self-cleaning ovens that fry the electronics of the ranges but I believe that this is often the case - don't know about Miele.
Heat is the enemy of all electronics. I doubt that even a manufacturer such as Miele could figure out a way to explain uncongenial truths to its customers, such as the idea that self-cleaning features are for emergency use, and do in fact shorten the life of the electronics.
Here is a link that might be useful: What's killing Apple's Time Capsules after 18 months?
The vast majority of Miele's service people don't work for Miele. They can and do say some outlandish and false things that are not the policy of the manufacturers.
This is such a case.
