Mon, Oct 15, 12 at 14:02
| After I used the self clean on my new Electrolux wall oven, it would not heat over 100 degrees. So, the thermostat was replaced and it works fine again. My question to Electrolux owners is: Did that fix the self clean problem, or did it happen to you again when you used the self clean? Should I just manually clean it? |
| This did not happen to me. I've self-cleaned mine three times. I would try to clean it again right away so it's still under warranty. This is not supposed to be a common problem for Elux since 2010. |
