Does an U/C refrigerator require
eleena (
Tue, Oct 2, 12 at 12:33
| a designated outlet?
I hope not but need to be sure. :-)
TIA! |
RE: Does an U/C refrigerator require
| In the US code does not require a dedicated circuit for refrigerators, but it is recommended. |
| Ok, great! I have one for the full refrigerator but did not want to bother with the under counter one as it is not at all powerful. TX! |
| You should note, however, that many manufacturers of uc fridges specify a dedicated outlet in their installation manuals. Assuming the fridge is being installed as part of a permitted renovation, many inspectors will refuse to pass any installation that does not comply with the manufacturer's install instructions - so I'd recommend double checking before making any commitment. |
| No, the manual did not say anything about the outlet being dedicated, so I guess I am good. Thank you! |
| Just don't use a GFI. If it trips, the fridge will lose power. |
| That's a good point, plllog. If that outlet is part of the general use kitchen outlet circuit, it probably does terminate with a GFCI breaker switch. |
| ....and that is against code (not sure whether NEC or just local). I was dinged on that by an inspector. |
| OK, this brings a new question: Should I plug it into the receptacle that is specifically designated for DW/GD, according to the breaker panel? |
