freezer defrost
Posted by econo (My Page) on
Fri, Oct 5, 12 at 9:18
hello I have a sears upright freezer that is about 6 years old. works great but I would like to adjust the defrost cycle to come on overnight instead of during the day when it is being used. looked at the timer and it has a small dial that can be turned with a screwdriver. would this be a matter of just advancing the timer or could that damage it.
Thanks
RE: freezer defrost
If its a defrost timer you can try this. Around 9pm turn the dial until you hear a loud click. It is now in defrost. It's most likely a 12 hour timer so this should keep it from turning on in the middle of the day
RE: freezer defrost
Turn slowly. There's a 2nd click very shortly after the first when the defrost period ends. If you pass the first click and trigger the 2nd, crank it back around for another try.
RE: freezer defrost
thank you! I will give it a try
RE: freezer defrost
I think you can also unplug it for a few hours each day until it is adjusted accordingly.
