JOIN NOW LOG IN
What Hood Vent for a 30 inch Blue Star
Posted by pearl2007 (My Page) on
Sat, Sep 12, 09 at 20:57
We're trying to figure out which hood vent to install for use with a RNB 30" Blue Star we are getting. At first I thought I'd just get the Blue Star vent. But then I started looking at / hearing about/ learning about other brands (eg. Vent a hood).... The one thing I know is we will get a 36" vent so it extends 3inches on each side of the Blue Star. If anyone who has a 30 Inch BS can share what vent they use and their experience / suggestions.... I'd like to hear about it.
Thanks.
RE: What Hood Vent for a 30 inch Blue Star
I installed a Prestige Proline 30" 1 week ago and so far so good. My vent run is about 2 1/2 feet. It pulls the heat and the smoke out with ease using the 600cfm fan. So far we love the oven and the hood. I purchased the Prestige over Vent a Hood because the stainless grids look easier to maintain over the Vent a Hood box. Only time will tell. The Prestige has a variable speed fan with Halogen lights that light up the full cooktop. Build quality is excellent. Hope this helps!
My friend put in a prestige for his 30" bluestar and has only great things to say about its performance (the hood, well, and the range)
Query...who makes blue star's rangehood?
I am looking to buy a 30' RNB from Bluestar. Why do you need the hood to extend three inches on each side of the BS? Is this a requirement?
I have the 36" Prestige for my 30" BlueStar. Love both. The Prestige is a dream machine that matches the power of the BlueStar burners. It's better to get the 36" for the 30" because of the capture area. I believe Prestige makes the BlueStar hoods. BTW, for disclosure, I am heide08's friend.
Yoyopa, thanks for the reply. So when you ordered your range did you order a Blue Star hood... or did you order a Prestige hood. I'm asking because you thought Prestige made the Blue Star Hood....
Bluestar makes their own hood and the Prestige hood
Is there a difference between a hood ordered under the Blue Star Branding and one ordered under Prestige.... are they basically the same hood?
I believe the big difference is you can get the Bluestar hood in the Bluestar colors. The Prestige branded one is only available in SS.
I love my Prestige hood--I splurged on the wall switches too. I was afraid I wouldn't be easily able to reach the hood-mounted switches (I'm 5' 2") but turns out I could. The real issue is it's actually hot up there with the front 22K burner running full blast. It's only like $100 more, and maybe more from the contractor to do it.
I have a 36" range with a 42" Ventahood. We love the hood. You can have it on high and it is still very quiet. They also made the hood to match the color of the Bluestar range exactly.
tube,
You've done it now! You said Vent-a-Hood in the same post as the word "quiet". :)
I too have a VaH and it performs well in my kitchen. With regard to the overhang... it's a bit less important if you've got a wall mounted vent with surrounding cabinets. There's a natural confined air space to give the hood more capture without the overhang extension. I've got an island hood which does benefit greatly from a slightly oversized hood.
Trevor,
Is the only difference between the bluestar hood and the prestige hood the color options? I figured I would get prestige but if they are the same I could get a color!
The units are the same, but remember the up-charge to paint a Bluestar hood
