| Thanks to everyone's rave reviews here, I chose the Electrolux 30" wall oven (EW30EW55GS) to be mounted under a Wolf 30" range. My architect is convinced that this cannot and should not happen, for three reasons:
1. The shape of the Electrolux oven would not accommodate the Wolf cooktop; (This is not clear to me from the spec sheets, nor will an Electrolux rep say definitively one way or the other.)
Thoughts? I really want to make this combo work. If I have to give up on the Wolf cookstop, can anyone speak to a successful installation of Elux wall oven _ Elux cooktop together? Thanks! Ally in Philly... |
| I was going to do this (other brands), but I tried some in the appliance store. Mounting a separate oven under a cooktop made the oven even lower than one in a range, which was just too low for my wife's bad back. This may not be a concern for you (and would not if it were just me). If you decide to go with Elux + Elux, I suggest that you consider the induction range EW30IS65JS.
| If you have room, there is the possibility of not installing the oven and cooktop together, one above the other. That way you would also have more options when it comes to replacement appliance choices later. |
