| In our current home we have an OTR microwave, it isn't vented outside, and has a 300 CFM fan. Our range is a gas Maytag.
In the new build, there will be a KitchenAid Architect Series II KGCD807XSS gas downdraft cooktop. It is vented to the outside, and is rated at 325 CFM. My question is will this be ok? I typically brown hamburger, or make chicken (for stir-fry, etc). I don't sear anything. I usually don't use oil, except for a little in the stir-fry. I've noticed that the upper cabinets are messy from the current situation, and I don't want a repeat of that. The builder wants alot of money to put in a range hood, and only has a few options to choose from. Advice? Thanks! |
- Posted by hollysprings (My Page) on Mon, Aug 6, 12 at 17:17
| Put in a range hood. It is so worth it. Downdraft and gas don't work well together. If it sucks enough to actually contravene the laws of physics by sucking all that rising hot air downward, then it sucks enough to pull the flame on the gas. 325 CFM is also beyond meager in dealing with the cooking byproducts that will coat your home. You're building from scratch. If youc can't do it right from the beginning, when can you? |
| It all depends on what you mean by "lots of money" but if your builder is making it sound like rocket science, then consult another builder. Better to find your own sub and tell you builder to discount anything that was built into your contract than be unhappy with the results afterward. To give you some idea of relative cost, we spent about 50% of the cost of our range on ventilation. Not all people cook the same and I will admit the type of cooking I typically due does push ventilation systems pretty hard so adjust your expectations accordingly. Good luck. |
| An induction cooktop because it does not heat the room air requires less ventilation. It would still benefit from a smaller hood, but probably could get by without makeup air. |
| Never seen a downdraft that did even an adequate job of removing grease, steam or odors from cooking. Cut costs elsewhere but get a proper hood vent. Most important things in a kitchen are the cooktop and its venting. everything else is secondary... |
- Posted by maire_cate (My Page) on Mon, Aug 6, 12 at 21:09
| I'm so tired of hearing that a downdraft doesn't work with a gas cooktop. I often wonder if the naysayers have ever used a good one for any amount of time. Of course an overhead hood is more efficient- but there are many reasons why it isn't suitable for every kitchen. 25 years ago we installed a Thermador downdraft and cooktop when we replaced an inoperable Jennair unit. 5 years ago we remodeled the kitchen and installed a Dacor downdraft with remote blower and a Dacor gas cooktop (17,000 BTU burners). We stir fry occasionally, fry bacon on a griddle, sear steaks in a cast iron skillet, boil pasta, cook fish etc. Our ceiling hasn't discolored, nor is it coated in grease, our house doesn't have lingering odors, the flame isn't pulled away from the burner and we've been very happy with the arrangement. Now if I had gas cooktop with 23,000 BTU's I would certainly reconsider the application. |
| I'm also a naysayer with direct experience of a GE Monogram gas cooktop with GE Monogram downdraft. Even with the sadly underpowered cooktop, the downdraft was next to useless. The cabinets all around the cooktop up to the 10' ceiling had grease residue from years of cooking with this setup. It took a lot of effort to get this to an acceptable state of cleanliness. I used this for about 7 months and couldn't wait to get rid of it. I see posters on this forum cheerily posting about their downdrafts, or even not having any ventilation and I wonder why their experiences are so different from mine. When I cooked on the Monogram, not only could I see visible deposits on the wall behind the cooktop and cabinets above but food smells drifted and lingered thoughout the house. We went to considerable trouble and expense to install overhead ventilation. This meant going into the wall and installing ductwork up and through the new roof. We also chose induction over the Bluestar cooktop I had always wanted, because there was no easy way to vent from the high power of a gas cooktop. We put in a 720 cfm Kobe hood and I'm very, very glad we did. Cheryl |
| Thank you all very much for your replies! It's a national builder, so we can't consult another builder. For the lowest end one they want 3500. That seemed steep to me. They also want me to upgrade the cook top to a different one. I've read that one reason for a kitchen remodel is to add a vent hood, and that's why I wanted to figure it out before hand! |
| National, nternational or local you are the purchaser. You may have to put in some extra effort to end up where you need to be. The long term use for this is worth it. Post a floor plan and this forum and the electrical can help you plan and price an option. You may then be able to delete that segment from your builders list of responsibilities and receive a credit for work not done and an appliance not supplied. |
- Posted by maire_cate (My Page) on Wed, Aug 8, 12 at 7:52
| jscout is correct and I should have been more specific - both of my units were pop ups. I agree completely about the inadequacy of a downdraft without a pop up vent. That's one of the reasons we replaced the Jennair. |
| My downdraft was a popup and it was next to useless. |
