Fri, Aug 10, 12 at 8:52
| I recently bought this pan.
http://circulon.dedicatedcookware.com/product/45-qt-extra-deep-all-pur pose-pan-infinite-collection I am used to pans heating up super fact on my induction stove -- this one heats up considerably slower. Any reason why? Makes me hesitate to buy any more from this line. |
| Either it has much greater mass than the reference pans or it doesn't have enough magnetizable material (magnetic susceptibility) to efficiently use the fields generated, or you are watching it. :) kas |
| Kaseki, thank you for your posts, you educate us on [a] the technical aspects of the item under discussion, [b] the exact and apt use of the English Language and importantly,........ [c] make us smile. Thank You. |
- Posted by weedmeister (My Page) on Fri, Aug 10, 12 at 15:15
| I have some Circulon frying pans. They are aluminum with a steel/iron slab welded to the bottom. It takes longer for them to heat up than my AllClad (thermal mass and all). I don't use them that much because they are noisier. |
| I have a small Circulon Infinite non stick pan as my induction omelet pan. No problems with it at all, but it's a pretty small pan. Just sayin' the whole line isn't bad--might have to do with the size and how much of it is inductable. Or somethin'. |
- Posted by westsider40 (My Page) on Fri, Aug 10, 12 at 21:41
| I have 4 Circulon Infinite pans, bought at Macy's. They all work fine, are not slow to heat and not noisy. |
