Internal freezer of refrigerator ices up
Posted by bobb1 (My Page) on
Fri, Jul 6, 12 at 21:51
I have a hand-me-down refrigerator that I am having problems with. It was fine until summer, then it started icing up.
It is a Kenmore, and the freezer is inside the refrigerator. The freezer box/compartment is a hallow metal drum type of contraption with a flimsy plastic door, situated inside the refrigerator at the top. Beneath is what I believe is a drip tray. I think the freezer box cools the entire unit. I don�t see modern refrigerator�s built this way.
So the refrigerator can maintain cold, the freezer metal drum has ice on it and for the most part it seems to work during fall to spring. Then summer came and the freezer compartment starts to ice up. I thought it was the increased humidity but the seal seems fine (acknowledging that it may not be as air tight as it can be despite how it looks).
The whole unit only has one dial and it is a simple dial that goes from off to A, B, C, D, Hi. I tried lowering the setting but that just seems to slow down the ice build up, not completely stop it. The freezer compartment has no controls. In the back there is a side-mounted small red hallow tubular intrusion into the freezer that I have no idea what it does.
Is there anything I can do to fix this myself? As you can imagine this ice build up is quite annoying.
Would a further decrease to the dial setting work?
Given a choice between calling a repair man and buying a new fridge, I�m tempted to buy a new one but I like to salvage it if I can.
Thank you
Bob
RE: Internal freezer of refrigerator ices up
What you are describing sounds like normal operation. That is why people avoid them and buy auto defrost.
The "red tubular" may just be a thermostat. If your fridge is really old it might be a manual defrost switch but I doubt it.
After you have defrosted using the link instructions, dry the area around the red tubular thing and look at it carefully for the words "cold" and "defrost" stamped on the metal with the short end of the tubular "L" pointing at "cold".
Here is a link that might be useful: Defrosting
Normal ?!? ok thanks. For now I'll defrost manually. And that red tubular thing doesn't appear to be a dial, it is a holder for the Thermometer probe.
Thanks again.
