JOIN NOW LOG IN
Any Wolf gurus in the house - clicking burners
Posted by chefwong (My Page) on
Tue, Jul 28, 09 at 19:42
Since Week 3 of owning our Wolf DF304 stove, we have had occasional issues with clicking burners. We have had at least 3-4 visits by the Wolf service tech and we just stopped calling them..
It's gotten to the point now that it's driving me insane. It will go *clicking* forever and I will leave it alone, and come back to use the burner 20 minutes later after spending 20+ minutes getting the burner to operate click free and when I use it....it's not clicking.
Any idea or advice you can point me to on how to make these damm burners stop clicking..
RE: Any Wolf gurus in the house - clicking burners
Are the metal circle discs in the center of the burners (burner covers) seated correctly?
I'm stumped. Never had that problem with mine. The grill unit will click-tick for the first few minutes, then it stops by itself.
Friend of mine has a Miele gas range. Her burners click 100% of the time- and she says the salesperson told her that was the way it was supposed to be!!!!!!!
Yes, they are seated right. The initial things the Wolf tech would do would be to remove the discs and actually slightly loosen or tighten the brass nut under the cover. It's been at least a year since he has been here.
Tonight I couldn't take it. I had 2 burners that was doing this.....and fidgeting with it while other burners were cooking away was not fun. Lo and behold, I decide to use it again and it's click free...
I wish there was a definitive answer/resolution to this...
Any chance the burners or ignitors are wet - my DCS burners will click for a while when wet but then stop. Could also be a faulty ignition module.
Check the polarity of your electrical outlet. You can buy a little three prong tester at the hardware store - the most difficult step will be pulling out the range to get to the plug/cord.
We just purchased a 30" RNB BlueStar range and had a similar problem -- clicking drives me nuts. When we checked and fixed the polarity - the problem was 100% resolved.
Here is a link that might be useful: polarity tester
Polarity, spills or air shutters.
Air Shutters. Can you explain or clarify on this.
I don't expect it to be a polarity issue as when the kitchen was gutted and redone, all receptables were done as well. Let me double check...I have to undo it from the box, a simple tester won't work as it has got a beefy receptacle on it.
chef -
if a plug fits in the recpt. , then the tester will too.
No need to undo the plate and recpt.
The plug is a 220 30 AMP. Not your normal sized receptacle -- where a standard tester works. Something like this
http://secure2.data-comm.com/stores/r/RBIS/catalog/1PKB1.JPG
Anyhow, I just confirmed the wiring. Looks correct to me.
Any other suggestions....
Don't assume because your kitchen was gutted and all the electrical work redone that the polarity is correct.
Our kitchen was gutted and rewired, when we experienced the polarity problem -- I asked our electrician to check the polarity, and he admitted that the helper (since fired)who wired the outlet could very well have wired it incorrectly... he did and it's now fixed.
I hear ya.....hots are on brass, neutral is correct.
I'm starting to notice a trend or not. Seems like when one is acting up, whether it be the front or back, the corresponding alternate - front clicking, the back will click too.
or vice versa...
Maybe it's coincidental ?
on ranges these days, when one burner clicks, they all click - that's how it works - only the one with the gas turned on will ignite
If it is moisture from wiping down the top before cooking, that seems to stop in just a minute or so. I once had to get a small cleaning brush and brush off the area -- apparently some small amount of cleaner or debris got stuck and it might have clicked forever.
On my Wolf dual fuel only the burner for use clicks.
sorry chef- I thought we were talking a rangetop here, not the range, my mistake.
We have this problem with the DCS that we installed. We never have gotten solved completely. Sometimes the burner (any of them, just using singular for the example) will click and click but not light, sometimes it will light but keep clicking.
According to the DCS brochure, this means the ignitors need cleaning. However, sometimes I could clean them daily with a toothbrush and mineral spirits, and still have the problem. I've also taken apart the burners and cleaned the simmer plates. I did also have the spark module replaced, since the DCS tech thought that might be a problem.
The only clue I have is that it really makes a difference what's used to clean the stove. Our old cleaning lady used to use Easy Off, despite my telling her repeatedly not to, and it would gum up the ignitors. We've had much better luck with Windex-type cleaners.
I couldn't take it any more...it's been at least 1 year + since I had the Wolf service rep over but I have them scheduled for next week.
How common is clicking burners on $$$$ stoves or is it just the nature of the beast - due to design - electrical ignitors.
Our previous vintage stove.....while always had a gas pilot on....was never as troublesome in this dept.
There are times where I will use the stove in the evening click free. Come early morning, it's clicking again.
