| I really really need a new range, and am in love with the NXR. I know people here hate OTR microwaves, but at this point, it will have to do...so can I use one with an NXR? I think I've seen pics here of that set up...I also need to internally vent it for now.
Suggestions? What exhaust output do I need ? 400? thank you for any input:) |
- Posted by GreenDesigns (My Page) on Mon, Jul 9, 12 at 0:55
| An OTR is completely inadequate for that amount of firepower. There isn't an OTR made that would work. It might even actually melt some of the components if you fired up a couple of the burners. You cannot look at a pro style range as a standalone purchase. You've got to look at the whole package needed, including the required ventilation hood and makeup air needs. |
| Well,if you are thinking about a 36-inch NXR, I would pretty much agree with GreenDesigns. But, with a 30-nch NXR, an OTR might not be great, but there are numbers of folks here who have done okay with them. I definitely would look at 400 cfm units and would look at mounting it has highw above the stove-top as is practical. Nunyabiz has posted here about this subjct. I believe the link below will show you nunyabiz's set-up with his/her/their NXR and OTR. Do a search on "OTR + NXR" and you will find a number of threads. |
Here is a link that might be useful: thread with pics of nunyabiz's NXR & OTR
- Posted by PAINTEDPEGGIES (My Page) on Mon, Jul 9, 12 at 8:48
| I am looking at the 30". I guess my question should be, what cfm power do I really need for that range? thanks for the links..that is the poster I was thinking of! Maybe she will chime in here... |
| If you're not going to vent outside, then the CFM aren't really relevant - the more CFM, the faster you'll recirculate the hot air back into your kitchen. If you have to go with an OTR then you really want to vent it outside. |
| JW is correct, with 30" you can get away with it if you use no less than 400CFM which as far as I can tell comes in only ONE OTR microwave which is the one I have. I don't think I have ever seen a OTR with more than 400cfm and at the time I bought mine it was the only one that had 400cfm that I could find. It works fine but it will get a bit overwhelmed if I start cooking several slices of bacon and 6 eggs on my 2 burner griddle plus the other 2 burners going with what ever and biscuits in the oven. 36" and yeah you can forget about using ANY OTR. We have ours vented inside through the internal charcoal filter and except for a very few occasions it does the job adequately. We bought the LG LMHM2017ST It has been a great microwave, no issues, lots of power and options, great "warming feature" and I think the best ventilation on any OTR microwave. "Ideally" in a perfect world and if money were no object you should use roughly 1CFM per each 100BTU. |
Here is a link that might be useful: LG LMHM2017ST
- Posted by oceangirl67 (My Page) on Mon, Jul 9, 12 at 12:06
- Posted by PAINTEDPEGGIES (My Page) on Mon, Jul 9, 12 at 12:25
| thanks for the info and links..I really have my heart set on the nxr, so I need to find a way to make it work:) |
| I have a 300 cfm Advantium OTR over my range. My range does not have the power that an NXR does (but then, I can't really see a situation where I'd be cranking out 4 burners of food on high heat either). I've had a 300 cfm OTR since moving into this house, 8 years ago. Until last month, it was always internally vented, and quite frankly, the venting was a joke. Anything remotely smoky and the vent was immediately overwhelmed. I paid a handyman a few hundred last month to install an external vent. My range is on a external wall, so there isn't a lot of turns and twists or extensive demo that had to be done. He basically measured, drilled a hole through the cabinet, drilled a matching hole through the siding, and hooked up the vent tubing (I'm sure there's a technical term for that but I have no idea what it is.) The difference is night and day. Sure, it could be better if the vent was a 900 cfm vent, but...in MN, make up air is required for anything over 300 cfm, and that's not an expense I want right now. I purposefully cooked something that I knew would set off the fire alarms pre-external venting the night it was installed. No fire alarms. Smoke in the kitchen was very minimal. I really wish I had looked into this years ago instead of assuming it would be thousands of $$$. I suggest you look into it before you dismiss it. |
