Bosch dishwasher settings
Posted by angiebangie (My Page) on
Tue, Jul 24, 12 at 17:15
I just got a new Bosch INtegra 500 this afternoon, and I can't wait to NOT rinse my dishes!!! I'm itching to cook something big and messy so that I can use the dishwasher tonight. If I can force my family into being lazy and not pre-rinsing the dishes, what cycle is best to use? Auto or normal? Do you use the sanitize function with every load? Thanks!
RE: Bosch dishwasher settings
Auto is an allround cycle - I use it like 70% of the time. Our dishwasher also has autoHeavy and Quick Wash, which I use sometimes - that's the other 30%. Sanitary will give you better drying but I don't think you'd need it to sanitize the dishes as such. Dishwasher detergent is pretty strong by itself and reduces bacteria to a save level, I think.
HTH, Alex
Thanks Alex. I used the sanitize cycle to get a hotter temp because I figured it would help with the drying. I also used the auto cycle, but I've only run the dishwasher once so far. I only had one plastic cup with water on the concave top, but everything else was pretty dry. It certainly dried better than my builder grade Dishwasher that was replaced.
My sanitize cycle is labeled "Power." I only use it when I wash my range burner heads, grates and vent baffles, which is maybe every two or three months. Otherwise, I just leave it on Auto, even for half loads. My reasoning is that while it's only washing a half load, it's also keeping the interior clean since there's little obstruction in the DW. I usually save up for a full load, so that's only happened a couple of times. I've only used the quick wash two or three times while entertaining. My guess is I'm running the DW 95% on Auto.
