Cleaning a deep fryer basket
Posted by tbonekel (My Page) on
Sun, Jul 26, 09 at 13:59
I bought a very dirty Nesco deep fryer at a garage sale. Everything cleaned up very nicely but the fryer basket. I don't think I will be able to find a replacement because I think the model is discontinued. If I new of a good way to clean the basket, I would. Can someone tell me a good way to clean this. It may need some acidic bath of some sort but I'm not sure. Any help would be greatly appreciated.
RE: Cleaning a deep fryer basket
You could try cold oven cleaner on it. I'd saturate it in the stuff in a plastic garbage bag and let it sit for a while.
By the way, you ought to call the manufacturer - even if the model is discontinued they might still have parts or a new model might have a basket that would fit.
There are recalls on some of their models. Check Nesco.com
The wire baskets for small appliances are usually tin or chrome plated wire and will start rusting if something like the lye based commercial food service fryer cleaners are used regularly if they are even available to you where you live. The basket set just below simmer in a large pot of water with some Kirkland powered detergent stirred in will eventually clean up with the use of a stiff bristle denture type brush and some small picks or screwdrivers.
Once it is cleaned up the easiest way to keep it staying clean longer is to use peanut oil, which is quite expensive. Can't win!
